5 Pages<1234>»
vfxblend
#21 Posted : Sunday, October 30, 2016 12:33:55 PM(UTC)
vfxblend
Was thanked: 32 time(s) in 10 post(s)
doggy wrote:
@ vfxblend
Has same problem until I installed the VLC NDI plugin
May I suggest to add this in the Readme file ?
Guy
What version of windows are you runnning?
vfxblend
#22 Posted : Sunday, October 30, 2016 12:35:19 PM(UTC)
vfxblend
palco5 wrote:
vfxblend wrote:
palco5 wrote:
Not working.
Not run aplication.
Did you check the README file?
1. Make sure you have JRE 1.8.0_77 x64 or higher installed
2. Make sure you have VLC x64 installed
3. Extract vMixTask and run vMixTask.exe
Yes sure
I have JRE 8.0_102
I have VLC x64
Is your JRE 64bit?
#23 Posted : Sunday, October 30, 2016 1:22:59 PM(UTC)
vfxblend wrote:
doggy wrote:
@ vfxblend
Guy
Windows 10
palco5
#24 Posted : Sunday, October 30, 2016 3:41:34 PM(UTC)
palco5
vfxblend wrote:
palco5 wrote:
vfxblend wrote:
palco5 wrote:
Not working.
Not run aplication.
Yes sure
I have JRE 8.0_102
I have VLC x64
Is your JRE 64bit?
Yes
palco5 attached the following image(s):
amonerdj
#25 Posted : Sunday, October 30, 2016 5:11:47 PM(UTC)
amonerdj
any tutorial for using?
vfxblend
#26 Posted : Sunday, October 30, 2016 6:31:23 PM(UTC)
vfxblend
Sure uploading tutorial
vfxblend
#27 Posted : Sunday, October 30, 2016 6:46:16 PM(UTC)
vfxblend
palco5 wrote:
vfxblend wrote:
palco5 wrote:
vfxblend wrote:
palco5 wrote:
Not working.
Not run aplication.
Yes sure
I have JRE 8.0_102
I have VLC x64
Is your JRE 64bit?
Yes
I am sure your vlc is 32bit
if its 64bit, its should be located here C:\Program Files\VideoLAN\VLC
pls verify
palco5
#28 Posted : Monday, October 31, 2016 3:49:46 AM(UTC)
palco5
vfxblend wrote:
palco5 wrote:
vfxblend wrote:
palco5 wrote:
vfxblend wrote:
palco5 wrote:
Not working.
Not run aplication.
Yes sure
I have JRE 8.0_102
I have VLC x64
Is your JRE 64bit?
Yes
pls verify
O, Thanks!
Im instal VLC for 64-bit, and work.
But, need tutorial for using.
Maximus
#29 Posted : Monday, October 31, 2016 9:36:43 AM(UTC)
Maximus
I installed VLC 64 bit and latest JRE but vMixTask is always stuck at Splash Screen and the only way to close it is to Reboot. I am Running Win 10 64 bit.
Any Suggestions?
Maxi
vfxblend
#30 Posted : Monday, October 31, 2016 11:33:39 AM(UTC)
vfxblend
Any Suggestions?
Maxi
Pls check if your latest JRE is 64bit and also there is no need to reboot if it get stuck
just go to task manager and end the Java Processes
vfxblend
#31 Posted : Monday, October 31, 2016 11:59:35 AM(UTC)
vfxblend
Sorry for delaying but my internet bad
here is a tutorials on how to use it
thanks 1 user thanked vfxblend for this useful post.
coolnetgr on 10/31/2016(UTC)
vfxblend
#32 Posted : Monday, October 31, 2016 12:03:05 PM(UTC)
vfxblend
how to use vMixTask
coolnetgr
#33 Posted : Monday, October 31, 2016 12:43:14 PM(UTC)
coolnetgr
Seems that in order to work, everything must be on C:\ ... I installed Vmix on D:\ and all my media files are on D:\ and I can't make it work.
In another computer where everything (Vmix, media, VLC and Java JRE) was on C:\ worked fine.
vfxblend
#34 Posted : Monday, October 31, 2016 12:54:05 PM(UTC)
vfxblend
Media files can can be anywhere, but VLC 64bit and JRE 64bit must be on C:
Maximus
#35 Posted : Monday, October 31, 2016 3:04:26 PM(UTC)
Maximus
I had to reinstall JRE and now it is working. Is there anyway to start/stop preview video when playing in bottom window? The potential is great for my use, especially if it is possible to break a Programme to insert Advertising. If video is 1 hour, I would like to interrupt playout to insert Promos or Advertising at specific points in the Playback.
vfxblend
#36 Posted : Monday, October 31, 2016 3:47:26 PM(UTC)
vfxblend
Am Happy its working now
will introduce a mute button for preview but for now the workaround is to select any TAG in your list. this should stop the playback
am currently working on trim in and trim out which should solve your issue of inserting promos between a long file.
thank you.
Maximus
#37 Posted : Monday, October 31, 2016 5:25:11 PM(UTC)
Maximus
Great potential vfxblend. You might also want to add a copy function for an item already in the Playlist so it can be used multiple times (Promos, Ads etc.). It would also be nice if they list order would allow dragging files within the list for reordering.
Stability so far has been good.
vfxblend
#38 Posted : Monday, October 31, 2016 6:52:18 PM(UTC)
vfxblend
thank you maxi
vfxblend
#39 Posted : Monday, October 31, 2016 6:57:49 PM(UTC)
vfxblend
Hi guys there is going to be a daily update of vMixTask
and will always consider your whishlist
J'chap on 11/1/2016(UTC)
ask
#40 Posted : Monday, October 31, 2016 10:59:37 PM(UTC)
ask
Hi, Did you upload the tutorial? If so where?
Also would it be possible to add a check for the JRE and VLC 64 bit versions at startup? At the moment the program simply hangs without any indication of what is missing.
Andrew
Guest (12)
5 Pages<1234>»
