66 Pages«<89101112>»
elgarf
#181 Posted : Friday, October 14, 2016 2:53:55 AM(UTC)
elgarf
Russian Federation
Was thanked: 230 time(s) in 130 post(s)
You can change color of ellipse by changing "t1" text.
File Attachment(s):
test.xaml (2kb) downloaded 127 time(s).
tkachuk.alex
#182 Posted : Sunday, October 16, 2016 4:18:22 AM(UTC)
tkachuk.alex
Ukraine
Thanx a lot
elgarf
#183 Posted : Wednesday, October 19, 2016 5:19:39 AM(UTC)
elgarf
Russian Federation
Controller updated with tags into list items.
Example: list item text@tag.
First post
Loosk like it still actual in vMix 18 :-)
elgarf
#184 Posted : Monday, October 24, 2016 11:17:34 AM(UTC)
elgarf
Russian Federation
Updated with state dependent buttons, tribute to post #126.
State dependent buttons
Button can check it's activeness by checking vMix API state, for example, you have script with OverlayInputToggle command, so button will light green if overlay is active and red if not. If you have more than one command in your script, button check statements for all commands (all overlays active or something else).
First post
thanks 2 users thanked elgarf for this useful post.
Jedda on 10/24/2016(UTC), corporatejames on 10/26/2016(UTC)
JAIRODJ
#185 Posted : Tuesday, October 25, 2016 12:25:09 PM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
@elgarf
Excellent, thank you very much .. thus I will know which button is activated
Thank you
Thank you
Thank you
elgarf
#186 Posted : Wednesday, October 26, 2016 12:58:17 AM(UTC)
elgarf
Russian Federation
@JAIRODJ, I saw that it very handy to see which button is activated, when I worked at volleyball broadcasting)
thanks 1 user thanked elgarf for this useful post.
fundownunder
#187 Posted : Friday, October 28, 2016 5:53:04 PM(UTC)
fundownunder
Groups: Guests
Hi elgarf,
first of all "great work" and communication level with other members regarding UTC.
I have downloaded the 3 folders from your first post and was able to get a scoreboard and news headline going using UTC.
What I can't do is 'File/Save' which means I have to start all over again.
Any ideas?
elgarf
#188 Posted : Friday, October 28, 2016 11:25:16 PM(UTC)
elgarf
Russian Federation
@fundowner, hmm... if you can share log file it will help.
It's in your documents, folder "vMix UTC/logs".
fundownunder
#189 Posted : Saturday, October 29, 2016 2:47:42 AM(UTC)
fundownunder
Groups: Guests
@elgarf... I found the file... it's massively long after doing a few things in UTC
2016-10-28 19:36:26.9992 INFO Loading mapped functions.
2016-10-28 19:36:27.0192 INFO Loading templates.
2016-10-28 19:36:27.1192 INFO Loading window settings.
2016-10-28 19:36:27.1432 INFO Trying to send function in async mode.
2016-10-28 19:36:27.2742 INFO Async function sended, result is "<vmix><version>17.0.0.107</version><inputs><input key="b0a36d02-d991-424e-8019-fa43d84cc2dd" number="1" type="Image" title="end.jpg" state="Paused" position="0" duration="0" loop="False">end.jpg</input><input key="c1b03ea9-2a83-4e61-adef-23fd6f2f6452" number="2" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="4ef7a8c1-0c08-48ba-a476-5fd0a72394ff" number="3" type="Xaml" title="ScoreBoardHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">ScoreBoardHD.xaml<text index="0" name="HomeTitle">Home</text><text index="1" name="AwayTitle">Away</text><text index="2" name="HomeScore">0</text><text index="3" name="AwayScore">0</text></input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Fade" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>".
2016-10-28 19:36:27.2742 INFO Creating vMix state form <vmix><version>17.0.0.107</version><inputs><input key="b0a36d02-d991-424e-8019-fa43d84cc2dd" number="1" type="Image" title="end.jpg" state="Paused" position="0" duration="0" loop="False">end.jpg</input><input key="c1b03ea9-2a83-4e61-adef-23fd6f2f6452" number="2" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="4ef7a8c1-0c08-48ba-a476-5fd0a72394ff" number="3" type="Xaml" title="ScoreBoardHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">ScoreBoardHD.xaml<text index="0" name="HomeTitle">Home</text><text index="1" name="AwayTitle">Away</text><text index="2" name="HomeScore">0</text><text index="3" name="AwayScore">0</text></input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Fade" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>.
2016-10-28 19:36:27.3082 INFO vMix state created.
2016-10-28 19:36:27.3082 INFO New model setted.
2016-10-28 19:36:27.3082 INFO Configuring to 127.0.0.1:8088.
2016-10-28 19:36:27.3082 INFO Checking vMix server.
2016-10-28 19:36:27.3082 ERROR Error while connecting vMix server. System.Net.WebException: The request was aborted: The request was canceled.
at System.Net.ConnectStream.BeginRead(Byte[] buffer, Int32 offset, Int32 size, AsyncCallback callback, Object state)
at System.Net.WebClient.DownloadBitsState.SetResponse(WebResponse response)
at System.Net.WebClient.DownloadBitsResponseCallback(IAsyncResult result)
2016-10-28 19:36:27.4433 INFO Checking vMix server.
2016-10-28 19:36:27.4433 INFO Status changed to Online.
2016-10-28 19:36:47.0064 INFO Checking vMix server.
2016-10-28 19:37:21.6774 INFO Trying to send function in sync mode.
2016-10-28 19:37:21.6774 INFO Creating vMix state form <vmix><version>17.0.0.107</version><inputs><input key="b0a36d02-d991-424e-8019-fa43d84cc2dd" number="1" type="Image" title="end.jpg" state="Paused" position="0" duration="0" loop="False">end.jpg</input><input key="c1b03ea9-2a83-4e61-adef-23fd6f2f6452" number="2" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="4ef7a8c1-0c08-48ba-a476-5fd0a72394ff" number="3" type="Xaml" title="ScoreBoardHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">ScoreBoardHD.xaml<text index="0" name="HomeTitle">Home</text><text index="1" name="AwayTitle">Away</text><text index="2" name="HomeScore">0</text><text index="3" name="AwayScore">0</text></input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Fade" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>.
2016-10-28 19:37:21.6774 INFO vMix state created.
2016-10-28 19:37:21.6774 INFO Configuring to 127.0.0.1:8088.
2016-10-28 19:37:21.6774 INFO New score widget added.
2016-10-28 19:37:21.6774 INFO Opening properties for widget .
2016-10-28 19:37:27.0367 INFO Checking vMix server.
2016-10-28 19:37:35.0021 INFO Properties updated.
2016-10-28 19:37:42.1815 INFO Configuring to 127.0.0.1:8088.
2016-10-28 19:37:46.9438 INFO Opening properties for widget Home copy.
2016-10-28 19:37:47.0708 INFO Checking vMix server.
2016-10-28 19:37:53.1672 INFO Properties updated.
2016-10-28 19:37:55.5133 INFO Opening properties for widget Away.
2016-10-28 19:38:00.3526 INFO Properties updated.
2016-10-28 19:38:05.0698 INFO Configuring to 127.0.0.1:8088.
2016-10-28 19:38:05.0698 INFO New button widget added.
2016-10-28 19:38:05.0698 INFO Opening properties for widget .
2016-10-28 19:38:07.0809 INFO Checking vMix server.
2016-10-28 19:38:31.1763 INFO Properties updated.
2016-10-28 19:38:41.6989 INFO Trying to send function Function=OverlayInput1&Input=3 in async mode.
2016-10-28 19:38:41.7529 INFO Async function sended, result is "Function completed successfully.".
2016-10-28 19:38:42.2010 INFO Trying to send function in async mode.
2016-10-28 19:38:42.2010 INFO Async function sended, result is "<vmix><version>17.0.0.107</version><inputs><input key="b0a36d02-d991-424e-8019-fa43d84cc2dd" number="1" type="Image" title="end.jpg" state="Paused" position="0" duration="0" loop="False">end.jpg</input><input key="c1b03ea9-2a83-4e61-adef-23fd6f2f6452" number="2" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="4ef7a8c1-0c08-48ba-a476-5fd0a72394ff" number="3" type="Xaml" title="ScoreBoardHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">ScoreBoardHD.xaml<text index="0" name="HomeTitle">Home</text><text index="1" name="AwayTitle">Away</text><text index="2" name="HomeScore">0</text><text index="3" name="AwayScore">0</text></input></inputs><overlays><overlay number="1">3</overlay><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Fade" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>".
2016-10-28 19:38:42.2010 INFO Updating vMix state.
2016-10-28 19:38:42.2010 INFO Creating vMix state form <vmix><version>17.0.0.107</version><inputs><input key="b0a36d02-d991-424e-8019-fa43d84cc2dd" number="1" type="Image" title="end.jpg" state="Paused" position="0" duration="0" loop="False">end.jpg</input><input key="c1b03ea9-2a83-4e61-adef-23fd6f2f6452" number="2" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="4ef7a8c1-0c08-48ba-a476-5fd0a72394ff" number="3" type="Xaml" title="ScoreBoardHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">ScoreBoardHD.xaml<text index="0" name="HomeTitle">Home</text><text index="1" name="AwayTitle">Away</text><text index="2" name="HomeScore">0</text><text index="3" name="AwayScore">0</text></input></inputs><overlays><overlay number="1">3</overlay><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Fade" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>.
2016-10-28 19:38:42.2010 INFO vMix state created.
2016-10-28 19:38:42.2010 INFO Configuring to 127.0.0.1:8088.
2016-10-28 19:38:42.2010 INFO Calculating difference.
2016-10-28 19:38:42.2010 INFO Updating inputs.
2016-10-28 19:38:42.2010 INFO Firing "updated" event.
2016-10-28 19:38:46.6582 INFO Trying to send function Function=SetText&Value=2&Input=3&SelectedIndex=2 in async mode.
2016-10-28 19:38:46.6812 INFO Async function sended, result is "Function completed successfully.".
2016-10-28 19:38:47.0972 INFO Checking vMix server.
2016-10-28 19:38:48.5713 INFO Trying to send function Function=SetText&Value=3&Input=3&SelectedIndex=3 in async mode.
2016-10-28 19:38:48.6513 INFO Async function sended, result is "Function completed successfully.".
2016-10-28 19:39:07.1114 INFO Checking vMix server.
elgarf
#190 Posted : Saturday, October 29, 2016 3:40:59 AM(UTC)
elgarf
Russian Federation
@fundowner, can you try save controller, then compress log into zip? Do you see save file dialog?
digitalalps
#191 Posted : Friday, November 11, 2016 6:25:24 AM(UTC)
digitalalps
i need to create a scoring list with this data provided in an xml file Like this:
<DATA>
<RECORD>
<COLOR>7</COLOR>
<INDEX>1</INDEX>
<VEHICLE>4</VEHICLE>
<PILOTNUMBER>25</PILOTNUMBER>
<TRANSPONDER>4</TRANSPONDER>
<PILOT>Pilot Name 1</PILOT>
<CLUB/>
<COUNTRY>HRV</COUNTRY>
<LAPINFO/>
<TREND>0</TREND>
<LAPS>2</LAPS>
<LAPTIME>26.394</LAPTIME>
<ABSOLUTTIME>00:52.738</ABSOLUTTIME>
<BESTTIME>26.344</BESTTIME>
<BESTTIMEN>52.738</BESTTIMEN>
<MEDIUMTIME>26.369</MEDIUMTIME>
<FORECAST>23 10:06.487</FORECAST>
<PROGRESS>24</PROGRESS>
<DELAYTIMEFIRST>0.000</DELAYTIMEFIRST>
<DELAYTIMEPREVIOUS>0.000</DELAYTIMEPREVIOUS>
<STANDARDDEVIATION>0.035</STANDARDDEVIATION>
<CARID>0</CARID>
<VOLTAGE>n/a</VOLTAGE>
<TEMPERATUR>n/a</TEMPERATUR>
<SPEED>35.05</SPEED>
</RECORD>
<RECORD>
<COLOR>7</COLOR>
<INDEX>2</INDEX>
<VEHICLE>3</VEHICLE>
<PILOTNUMBER>5</PILOTNUMBER>
<TRANSPONDER>3</TRANSPONDER>
<PILOT>Pilot Name 2</PILOT>
<CLUB/>
<COUNTRY>DEU</COUNTRY>
<LAPINFO/>
<TREND>0</TREND>
<LAPS>2</LAPS>
<LAPTIME>26.817</LAPTIME>
<ABSOLUTTIME>00:53.757</ABSOLUTTIME>
<BESTTIME>26.817</BESTTIME>
<BESTTIMEN>53.757</BESTTIMEN>
<MEDIUMTIME>26.878</MEDIUMTIME>
<FORECAST>23 10:18.195</FORECAST>
<PROGRESS>26</PROGRESS>
<DELAYTIMEFIRST>+0.473</DELAYTIMEFIRST>
<DELAYTIMEPREVIOUS>+0.473</DELAYTIMEPREVIOUS>
<STANDARDDEVIATION>0.086</STANDARDDEVIATION>
<CARID>0</CARID>
<SPEED>34.50</SPEED>
</RECORD>
My problem, i can create a line with all the values in one record like this ?
1 Pilot Name 1 HRV 2 26.394 .................
2 Pilot Name 2 DEU 2 26.817 .................
elgarf
#192 Posted : Friday, November 11, 2016 7:51:57 AM(UTC)
elgarf
Russian Federation
@digitalalps, you can made XPath like this:
Code:
./DATA/RECORD/INDEX|./DATA/RECORD/PILOT|./DATA/RECORD/COUNTRY|./DATA/RECORD/LAPS|./DATA/RECORD/LAPTIME
it will make one value by row, so you can map each value to title placeholder.
digitalalps on 11/11/2016(UTC), corporatejames on 11/11/2016(UTC)
digitalalps
#193 Posted : Friday, November 11, 2016 8:54:35 AM(UTC)
digitalalps
Thx,
is working fine. Now i have a other problem:
The number of records in the xml is not fixed i can have 5 records, the next race 10 and so on.
I made a Overlay with 10 lies of datafields like this:
Index1 Name1 Time1
Index2 Name2 Time2
Index10 Name10 Time10
If i have 10 Records works fine, when i have only 7 records the line 8 brings the first record. The data restarts at beginn
elgarf
#194 Posted : Friday, November 11, 2016 9:29:26 AM(UTC)
elgarf
Russian Federation
@digitalalps, hmm... I thought it was a good idea to restart data =) I'll make chackbox, where you can switch off data restarting.
elgarf
#195 Posted : Friday, November 11, 2016 9:44:37 AM(UTC)
elgarf
Russian Federation
I've updated controller with "Restart Data" checkbox, try it.
First post
P.S. Did anybody need timeline into vMix? Where you can place inputs or control properties like loudness/opacity/etc?
digitalalps
#196 Posted : Friday, November 11, 2016 1:24:51 PM(UTC)
digitalalps
Great, works fine!!!
Thx
digitalalps
#197 Posted : Saturday, November 12, 2016 3:54:38 AM(UTC)
digitalalps
Has anyone any idea how to solve the following problem?
I have a variable long list of race results, which is deposited with a background.
I would like to have the background but only as long as the list is long, so what is possible with UTC?
For example with individual graphical segments per line which are switched off and on?
Thx for the help
elgarf
#198 Posted : Saturday, November 12, 2016 5:16:07 AM(UTC)
elgarf
Russian Federation
Can you share your title? You can make triggers inside your xaml.
elgarf
#199 Posted : Sunday, November 13, 2016 5:35:53 AM(UTC)
elgarf
Russian Federation
@digitalalps, you can make something like that (see attachment).
File Attachment(s):
NewsHD.xaml (6kb) downloaded 87 time(s).
digitalalps on 11/13/2016(UTC)
digitalalps
#200 Posted : Sunday, November 13, 2016 7:53:21 AM(UTC)
digitalalps
This solution will work perfectly.
I'm always surprised how powerful Vmix is.
Thanks to Martin and the community
7423158, Guest (14)
