Stream in different quality to different RTMP CDN's
Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
I have searched the forum but no luck in finding an answer to my situation.
I would like to send 3 streams at the same time. 2 identical encodings to a primary and a backup/secondary mount point at our CDN. 1 encoded with different bitrate than the first 2.
As I see it, the bottom part of the Streaming Settings are static for all 3 destinations. How can I differentiate the quality for different destinations?
We only stream to our CDN, not to Facebook, Periscope, Twitch, Ustream etc. Plain and simple RTMP.
-Keld Bendtsen
Quote:As I see it, the bottom part of the Streaming Settings are static for all 3 destinations. How can I differentiate the quality for different destinations?
It will add a 1, 2 and 3 to the end of the streamnames. So if your stream is rtmp://someserver.net/live/stream it will become: rtmp://someserver.net/live/stream1 rtmp://someserver.net/live/stream2 rtmp://someserver.net/live/stream3
Joined: 6/29/2016(UTC) Posts: 104 Location: Luxembourg
Thanks: 48 times Was thanked: 14 time(s) in 12 post(s)
What about using EXTERNAL in VMIX and capture the output with FMLE or OBS.
You can then define Stream settings as you like and send it via rtmp.
You can even open several instances of FMLE and/or OBS to differnentiate the quality but beware the CPU Usage.
Hope I could help.
Marc
mburel1980 wrote:What about using EXTERNAL in VMIX and capture the output with FMLE or OBS.
Hope I could help.
Marc Hi Marc I will definitely try out your suggestion. CPU usage should not be an issue. It's quite a powerful PC we're running on. -Keld
 1 user thanked KeldBendtsen for this useful post.
