djevo1
#1 Posted : Monday, October 17, 2016 9:48:36 AM(UTC)
djevo1
Was thanked: 8 time(s) in 7 post(s)
I just updated to vmix and noticed that when attempting to do a chroma key only the presets seem to function. The chroma key slider and RGB sliders no longer function to manually adjust the key. I select the color using the eyedropper, but only the filter slider functions.
#2 Posted : Monday, October 17, 2016 10:09:55 AM(UTC)
If you are referring to the difference between 16 and 17, the number 3 preset will configure things the same as "Auto Chroma Key" button on previous releases
but the controls should all work exactly the same otherwise.
Len56
#3 Posted : Monday, October 17, 2016 10:58:28 AM(UTC)
Len56
Yes Martin,
I can confirm all 3 settings in Chroma key the controls are all working fine, I am using vMix 17.0.0.112.
