Chroma key no longer functioning properly after latest update?
Was thanked: 8 time(s) in 7 post(s)
I just updated to vmix and noticed that when attempting to do a chroma key only the presets seem to function. The chroma key slider and RGB sliders no longer function to manually adjust the key. I select the color using the eyedropper, but only the filter slider functions.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
If you are referring to the difference between 16 and 17, the number 3 preset will configure things the same as "Auto Chroma Key" button on previous releases but the controls should all work exactly the same otherwise.
Martin vMix
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
Yes Martin,
I can confirm all 3 settings in Chroma key the controls are all working fine, I am using vMix 17.0.0.112.
