ccil
#1 Posted : Saturday, October 8, 2016 11:38:15 PM(UTC)
ccil
I have tested my vmix setup, on Windows 8, to connect NDI desktop to two different computers, Win 7 and Mac, and the display 2 appears as a option in vmix. But now trying NDI Desktop Capture on a Windows 10 computer display 2 is not coming up as an option in vmix.
Should NDI Desktop Capture be fully compatible with Windows 10?
What can I check to be the problem?
sinc747
#2 Posted : Sunday, October 9, 2016 12:46:13 AM(UTC)
sinc747
So you have a PC running vMix (the vMix PC) and a 2nd PC (Windows 10) with two monitors that is running vMix Desktop Capture. And when you add an input on the vMix PC, you select NDI/Desktop Capture, look at the NDI inputs available on the Windows 10 PC, and Display 2 is not an option? Did I state this correctly?
- Tom
AElli on 10/10/2016(UTC)
ccil
#3 Posted : Sunday, October 9, 2016 10:59:46 AM(UTC)
ccil
- Tom
Yes. correct!
Well, after a reboot, it seems to be working this morning. Always reboot first!
ccil
#4 Posted : Sunday, October 30, 2016 9:40:48 PM(UTC)
ccil
I continue to have this issue, desktop capture on Windows 10 to vmix on windows 8, the second display is not normally seen. At least once it did appear, not sure why and normally it is not.
Guest (4)
