NDI
display 2 not appearing in vmix through NDI desktop capture
I have tested my vmix setup, on Windows 8, to connect NDI desktop to two different computers, Win 7 and Mac, and the display 2 appears as a option in vmix. But now trying NDI Desktop Capture on a Windows 10 computer display 2 is not coming up as an option in vmix. Should NDI Desktop Capture be fully compatible with Windows 10? What can I check to be the problem?
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 203 time(s) in 169 post(s)
So you have a PC running vMix (the vMix PC) and a 2nd PC (Windows 10) with two monitors that is running vMix Desktop Capture. And when you add an input on the vMix PC, you select NDI/Desktop Capture, look at the NDI inputs available on the Windows 10 PC, and Display 2 is not an option? Did I state this correctly?
- Tom
 1 user thanked sinc747 for this useful post.
sinc747 wrote:So you have a PC running vMix (the vMix PC) and a 2nd PC (Windows 10) with two monitors that is running vMix Desktop Capture. And when you add an input on the vMix PC, you select NDI/Desktop Capture, look at the NDI inputs available on the Windows 10 PC, and Display 2 is not an option? Did I state this correctly?
- Tom Yes. correct! Well, after a reboot, it seems to be working this morning. Always reboot first!
I continue to have this issue, desktop capture on Windows 10 to vmix on windows 8, the second display is not normally seen. At least once it did appear, not sure why and normally it is not.
NDI
