66 Pages«<7891011>»
elgarf
#161 Posted : Wednesday, October 5, 2016 11:32:53 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@Jedda, can I look at it?
Jedda
#162 Posted : Wednesday, October 5, 2016 11:38:39 AM(UTC)
Jedda
Sure, I'll get it up whenever I'm at the vMix computer.
Jedda
#163 Posted : Wednesday, October 5, 2016 3:38:14 PM(UTC)
Jedda
This is the file I use which has been giving me problems.
File Attachment(s):
fotboll.zip (5kb) downloaded 124 time(s).
Jedda
#164 Posted : Wednesday, October 5, 2016 3:49:33 PM(UTC)
Jedda
Just downloaded the latest version, but I can't do anything in the program now? Not even going to File -> Open does anything at all. Anyone else having problems?
EDIT: Just tried reverting to the previous version I had saved on the computer, but it's the same there. Any idea why this is happening elgarf?
corporatejames
#165 Posted : Wednesday, October 5, 2016 11:32:33 PM(UTC)
corporatejames
@elgarf does the naming of a image effect if it loading. Some images loading every change of the XML using the binding work around.
eg FirstnameLastname.png But if the image is named Intro-Name-BG.png for example it does not always update the image in Vmix.
Loads first time but not always change if the name of the file changes in the xml like when changing the team so that it updates all the images.
I have not had issues at all on Starting Fives and they update instantly with not having a - in the image title.
Plus also if there is a image with the same name for a background more the once in a xaml title (different binding text field) but same image,
does not always load the second one. I have not tested it by making the second image image2.png so it it works. Could it be that the image is already
in use? You can had the same image multiple times in the Vmix to a XAML title so don't think that's issue but could be different coming from external data?
elgarf
#166 Posted : Thursday, October 6, 2016 12:30:06 AM(UTC)
elgarf
Russian Federation
@Jedda, your vmc is ok. I don't know why opening file does not work for you, can I see your log.
@corporatejames, naming of image shouldn't affect on image loading, but you can show me your log file.
If you need same image in different places, you can bind Source to one Text control into xaml file OR you can make textfield widget, which will connect data from titles. OR myabe new version fixed it :-)
corporatejames
#167 Posted : Thursday, October 6, 2016 12:49:59 AM(UTC)
corporatejames
I think the binding method is working ok. But does not always update vmix. unless I reload the xaml title by properties and clicking change in Vmix
which I just reload the same XAML title and it refreshes all the images from UTC and XML. Plus the data is working fine, if I check the field that I point the
image url to it has correct path. Just the image not always updating. But no issues with starting fives that work perfect :).
Jedda
#168 Posted : Thursday, October 6, 2016 3:22:27 PM(UTC)
Jedda
Here's my logs from yesterday and today when trying to open it. It really sucks, cause I'm a bit depending on this to work when having to stream on saturday :(
File Attachment(s):
logs.zip (4kb) downloaded 47 time(s).
elgarf
#169 Posted : Thursday, October 6, 2016 11:24:05 PM(UTC)
elgarf
Russian Federation
Hey, Jedda, there is error in your ip address: "Andreas Rodin127.0.0.1:8088", I'll fix exception, but you can just clear saved settings. Go to your documents folder and remove/edit WindowSettings.xml.
P.S. You can download new version.
thanks 1 user thanked elgarf for this useful post.
Jedda on 10/8/2016(UTC)
Jedda
#170 Posted : Friday, October 7, 2016 2:29:24 PM(UTC)
Jedda
Ahh, yes. Somehow it must have been pasted by me during the last match since Andreas Rodin was one of the players that match. Now it's working fine again. Never even thought this was something that could have such much affect on the program that I couldn't even load anything! Looks like no double clocks or anything either now, maybe all my problems will be fine now :)
Patuzzo
#171 Posted : Saturday, October 8, 2016 4:30:52 PM(UTC)
Patuzzo
Hi, I just downloaded your program. Just outstanding.
you can see the screen of a remote PC? In order to check the score from another pc?
Thank you!
Marco
ask
#172 Posted : Saturday, October 8, 2016 8:58:10 PM(UTC)
ask
You have been a member since:: 10/13/2012(UTC)
Thank you!
Marco
Bring in an NDI Monitor for this. Run Desktop capture on the remote PC or NDI Scan Convertor
tkachuk.alex
#173 Posted : Sunday, October 9, 2016 4:51:13 AM(UTC)
tkachuk.alex
Ukraine
Hi! Great programm, thx for your job.
Have a question, is it possible to change image in title? If yes - how it works.
If no - are you plane to do such functionality? Maybe a list of uploaded images with buttons 1, 2, 3.. etc, and change them after pressing or else
THX
Patuzzo
#174 Posted : Sunday, October 9, 2016 5:48:17 AM(UTC)
Patuzzo
Thank you!
Marco
Could you give me more information?
And if I want to check the score of tablet? With the web I do not see the score.
Thank you
elgarf
#175 Posted : Sunday, October 9, 2016 7:51:52 AM(UTC)
elgarf
Russian Federation
@Patuzzo, you need load NDI monitor module into external data widget, then take output from vmix or desktop capture or anything else.
@tkachuk.alex, you can change images, but you need to put them in computer with controlled vMix, and use full path to images.
tkachuk.alex
#176 Posted : Sunday, October 9, 2016 5:56:57 PM(UTC)
tkachuk.alex
Ukraine
So, I need to put images at vmix computer. At UTC create list and manually set all images that can be change at title?
elgarf
#177 Posted : Monday, October 10, 2016 12:24:37 AM(UTC)
elgarf
Russian Federation
Yes, manually or by external data.
tkachuk.alex
#178 Posted : Tuesday, October 11, 2016 6:38:43 AM(UTC)
tkachuk.alex
Ukraine
Coul'd you paste a n example please..
Ok, no need example. I understand my mistake. I use path from vmix with "file:///....", and when I change to normal "C://...." it work great.
So I used list with uploaded image pathes, and have a little inconvenience with long name at list.
Is it possible to make a checkbox to add short discription at list and name there images?
Example. Penalties at soccer, I have three circles white red and green colors. And I need to change them to proper color. If at list will be only discription like Red Green White, and choosing them changin proper color, it will be great.
elgarf
#179 Posted : Tuesday, October 11, 2016 7:27:58 AM(UTC)
elgarf
Russian Federation
@tkachuk.alex, you can use "table" checkbox, and make two fields: name|path, but map them to one title, just fast workaround.
I'll think about alternative text in the list widget.
Also you can change color of circle without images at all, I'll show an example later.
tkachuk.alex
#180 Posted : Tuesday, October 11, 2016 7:56:29 AM(UTC)
tkachuk.alex
Ukraine
THX
Guest (10)
66 Pages«<7891011>»
