Instant Replay
Duration event transition
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
Hello all
In my instant replay configuration I set the event transition to fade and 500ms.
If I play out some replay clips at 100% speed, the fade duration between events is approx. 500ms.
If I play out some replay clips at lower speed (ex. 25%), the fade duration feels much longer than 500ms.
Does the event transition duration really depend on the selected speed? Is this the correct behavior or probably a bug?
Regards, Patrick
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
There is also a flickering when using fade transition with a lower speed than 100%, have you experienced that as well?
Maybe those 2 problems have the same origin.
Instant Replay
