pm
#1 Posted : Thursday, September 29, 2016 2:32:23 PM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
Hello all
In my instant replay configuration I set the event transition to fade and 500ms.
If I play out some replay clips at 100% speed, the fade duration between events is approx. 500ms.
If I play out some replay clips at lower speed (ex. 25%), the fade duration feels much longer than 500ms.
Does the event transition duration really depend on the selected speed? Is this the correct behavior or probably a bug?
Patrick
Rinsky
#2 Posted : Tuesday, October 4, 2016 9:54:12 PM(UTC)
Rinsky
There is also a flickering when using fade transition with a lower speed than 100%, have you experienced that as well?
Maybe those 2 problems have the same origin.
