vince422
#1 Posted : Friday, September 16, 2016 7:24:00 AM(UTC)
vince422
We would use BlackMagic cameras on PTZ support with vMix.
We believe taking a PTZ head of this type ( http://www.optovision.fr/-Tourelles-.html MP-110 or MT-315) for movements, rotations.
For the zoom controls, focus ... we want to use the Blackmagic Design 3G-SDI Arduino Shield.
Do vMix might recognize this PTZ head? And will it be possible to send the zoom controls, focus on the Arduino?
Thank you. Cordially.
Vincent LEVEQUE
sinc747
#2 Posted : Sunday, September 18, 2016 11:52:53 PM(UTC)
sinc747
If the PTZ head supports network control it might work.
- Tom
vince422
#3 Posted : Saturday, September 24, 2016 7:28:50 AM(UTC)
vince422
Can I use this to control my PTZ head with vMix ?
Ethernet TCP / IP controller with 4 Serial Ports - RS232, RS422, RS485 : http://gridconnect.com/ethernet-tcp-ip-controller-with-4-serial-ports-rs232-rs422-rs485.html#
Thank you.
Vincent
sinc747
#4 Posted : Saturday, September 24, 2016 12:15:15 PM(UTC)
sinc747
I have no experience with this device, but looking at the specs it could possibly work. However, I doubt that it would be plug and play. Anyone else care to weigh in?
- Tom
Mathijs
#5 Posted : Saturday, September 24, 2016 8:09:32 PM(UTC)
Mathijs
It won't work at this moment.
I gave Martin a dev board of a similar device at IBC to see if he could implement support for this.
Check these different products.
When using tcp, even wifi would be an option.
thanks 1 user thanked Mathijs for this useful post.
sinc747 on 9/24/2016(UTC)
