Hello, We would use BlackMagic cameras on PTZ support with vMix. We believe taking a PTZ head of this type ( http://www.optovision.fr/-Tourelles-.html MP-110 or MT-315) for movements, rotations. For the zoom controls, focus ... we want to use the Blackmagic Design 3G-SDI Arduino Shield. Do vMix might recognize this PTZ head? And will it be possible to send the zoom controls, focus on the Arduino? Thank you. Cordially. Vincent LEVEQUE
Joined: 8/2/2013(UTC) Posts: 1,098   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
If the PTZ head supports network control it might work.
- Tom
I have no experience with this device, but looking at the specs it could possibly work. However, I doubt that it would be plug and play. Anyone else care to weigh in?
- Tom
It won't work at this moment. I gave Martin a dev board of a similar device at IBC to see if he could implement support for this. Check these different products. When using tcp, even wifi would be an option.
 1 user thanked Mathijs for this useful post.
