DanV
#1 Posted : Thursday, September 22, 2016 9:14:28 AM(UTC)
DanV
Greetings
My name is Dan and I'm new in vMix.
Can anyone advise how to configure VMix to output video and record video and sound?
My hardware:
1.Decklink Intensity (HDMI in , HDMi out), HDMI IN -camera connected
2.Decklink Extreme 3D (2xSDi In, 2xSDi out), SDI IN -camera connected
3.SDI Monitor connected to SDI output Decklink Extreme 3D
4.HDMI Monitor connected to HDMI output Decklink Extreme 3D
[img]
Testing if shown camera on Media Expres software from Blackmagic design:
1.Decklink Intensity... camera OK
2.Decklink Extreme 3D ... camera OK
On vMix:
INPUT Decklink Intensity camera (HDMI IN) - see
INPUT Decklink Extreme 3D camera (SDI IN) - see
INPUT a video file - see
External Output settings:
vMix Video:
Frame rate: PAL 50i
Output size 1920x1080
Outputs: Recording/External/Output
On outputs shown only Decklink Extreme 3D camera (SDI output and also on HDMI output).
if I stop the vMix, see nothing on Monitors.
Thanks for any reply.
DanV attached the following image(s):
decklink_extreme 3d settings.png (29kb) downloaded 11 time(s).
external settings_output.png (36kb) downloaded 7 time(s).
ask
#2 Posted : Thursday, September 22, 2016 9:20:39 AM(UTC)
ask
DanV
#3 Posted : Thursday, September 22, 2016 10:44:53 AM(UTC)
DanV
Thanks but not working.
I did that settings but have the sae error:
"StartStopExternal.Decklink Video Render
No combination of intermediate filters could be found to make the connection."
and if I chose the other Decklink board had this error:
StartStopExternal
Unable to cast COM object of type 'System.__ComObject' to interface type 'DecklinkPlugin.DeckLinkAPI.IDeckLinkOutput'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{CC5C8A6E-3F2F-4B3A-87EA-FD78AF300564}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Please tell me what should I do.
Thanks for your time.
#4 Posted : Thursday, September 22, 2016 10:58:30 AM(UTC)
Hi Dan,
The last error is the result of not having the latest Decklink driver installed, so try that first.
The other issues might be due to the limitation of the Decklink Extreme 3D.
Note that while it has many connectors on it for both input and output it is only a single channel device.
This means it cant be used as input and output at the same time.
DanV
#5 Posted : Thursday, September 22, 2016 11:16:46 AM(UTC)
DanV
Than you for your quick response Martin.
