No output see on Decklink Extreme
Greetings My name is Dan and I'm new in vMix. Can anyone advise how to configure VMix to output video and record video and sound? My hardware: 1.Decklink Intensity (HDMI in , HDMi out), HDMI IN -camera connected 2.Decklink Extreme 3D (2xSDi In, 2xSDi out), SDI IN -camera connected 3.SDI Monitor connected to SDI output Decklink Extreme 3D 4.HDMI Monitor connected to HDMI output Decklink Extreme 3D [img] Testing if shown camera on Media Expres software from Blackmagic design: 1.Decklink Intensity... camera OK 2.Decklink Extreme 3D ... camera OK On vMix: INPUT Decklink Intensity camera (HDMI IN) - see INPUT Decklink Extreme 3D camera (SDI IN) - see INPUT a video file - see External Output settings: vMix Video: Frame rate: PAL 50i Output size 1920x1080 Outputs: Recording/External/Output On outputs shown only Decklink Extreme 3D camera (SDI output and also on HDMI output). if I stop the vMix, see nothing on Monitors. Thanks for any reply. DanV attached the following image(s):  decklink_extreme 3d settings.png (29kb) downloaded 11 time(s). external settings_output.png (36kb) downloaded 7 time(s).You cannot view/download attachments. Try to login or register.
Thanks but not working. I did that settings but have the sae error: "StartStopExternal.Decklink Video Render No combination of intermediate filters could be found to make the connection."
and if I chose the other Decklink board had this error: StartStopExternal Unable to cast COM object of type 'System.__ComObject' to interface type 'DecklinkPlugin.DeckLinkAPI.IDeckLinkOutput'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{CC5C8A6E-3F2F-4B3A-87EA-FD78AF300564}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Please tell me what should I do.
Thanks for your time.
Joined: 1/13/2010(UTC) Posts: 5,334  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
Hi Dan,
The last error is the result of not having the latest Decklink driver installed, so try that first. The other issues might be due to the limitation of the Decklink Extreme 3D. Note that while it has many connectors on it for both input and output it is only a single channel device. This means it cant be used as input and output at the same time.
Martin vMix
Than you for your quick response Martin.
