alanppp
#1 Posted : Friday, September 16, 2016 8:02:24 PM(UTC)
alanppp
Guys!
We've been using a SAMSON MD13, witch works amazingly good with VMIX.
Well, It sunddley stopped working... We've tested on other apps and it works fine. But on VMIX it does not.
Is there anything we might have "missclicked" and disable the MIDI table option? I cant find it...
#2 Posted : Saturday, September 17, 2016 10:31:43 AM(UTC)
Go to Settings -> Shortcuts -> MIDI Settings to see if it appears in the list and enable it if not checked.
Then click Find and see if it picks up the buttons.
hubert17
#3 Posted : Friday, September 23, 2016 9:52:23 AM(UTC)
hubert17
Samson Graphite MD13 user here! :)
Martin is correct. Make sure you have check Samson Graphite MD13 in Midi Device List.
Let me share to you my MD13 midi controller shortcut template.
File Attachment(s):
Samson MD13 MIDI controller.zip (3kb) downloaded 11 time(s).
desmar
#4 Posted : Saturday, September 24, 2016 9:50:44 AM(UTC)
desmar
Canada
Having same issue with Behringer CMD LC-1, worked fine til I upgraded to vMix 17.0.0.108.
Not always recognized by vMix, but works in all my other software...
#5 Posted : Saturday, September 24, 2016 12:04:41 PM(UTC)
MIDI is unchanged in 108, so my guess is the settings got changed somewhere along the way.
desmar
#6 Posted : Sunday, September 25, 2016 12:37:29 AM(UTC)
desmar
Canada
nope, doesn't work, even tried reset to factory default, sees CMD LC-1 in midi devices and when you click find it doesn't see any keys..
#7 Posted : Sunday, September 25, 2016 7:09:39 AM(UTC)
Maybe it is a driver problem with 64bit? Most programs will be 32bit while vMix is 64.
Try the 32bit version of vMix to compare.
Failing that, please send through a formal support request via our web site:
http://www.vmix.com/contact-us.aspx
