MIDI TABLE NOT WORKING ANYMORE
Guys! We've been using a SAMSON MD13, witch works amazingly good with VMIX.
Well, It sunddley stopped working... We've tested on other apps and it works fine. But on VMIX it does not.
Is there anything we might have "missclicked" and disable the MIDI table option? I cant find it...
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Go to Settings -> Shortcuts -> MIDI Settings to see if it appears in the list and enable it if not checked. Then click Find and see if it picks up the buttons.
Martin vMix
Joined: 4/10/2016(UTC) Posts: 13 Location: Philippines
Samson Graphite MD13 user here! :) Martin is correct. Make sure you have check Samson Graphite MD13 in Midi Device List. Let me share to you my MD13 midi controller shortcut template. File Attachment(s):  Samson MD13 MIDI controller.zip (3kb) downloaded 11 time(s).You cannot view/download attachments. Try to login or register.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Having same issue with Behringer CMD LC-1, worked fine til I upgraded to vMix 17.0.0.108. Not always recognized by vMix, but works in all my other software...
MIDI is unchanged in 108, so my guess is the settings got changed somewhere along the way.
admin wrote:MIDI is unchanged in 108, so my guess is the settings got changed somewhere along the way.
Go to Settings -> Shortcuts -> MIDI Settings to see if it appears in the list and enable it if not checked. Then click Find and see if it picks up the buttons. nope, doesn't work, even tried reset to factory default, sees CMD LC-1 in midi devices and when you click find it doesn't see any keys..
Maybe it is a driver problem with 64bit? Most programs will be 32bit while vMix is 64. Try the 32bit version of vMix to compare. Failing that, please send through a formal support request via our web site: http://www.vmix.com/contact-us.aspx
