Hello, my idea is to realize a WebTV.
I want to create a web TV with youtube streaming. I thought of this computer setup, and I wonder if it's okay with your VMix software. I would use 3 INTENSITY PRO capture devices 4K of BlackMagic Design to connect three video cameras to the computer, but with these components, the computer will be able to withstand all inputs?
Motherboard: Asus Z170-A Processor: Intel Core i5-6500 3.2 GHz CPU with GPU HD Graphics 530 Boxed RAM: 16 GB DDR4 HDD: 240 GB SSD read 560 MB / s and write 530 MB / s
Thanks.
Joined: 12/19/2013(UTC) Posts: 600   Location: Belgium Thanks: 75 times Was thanked: 91 time(s) in 75 post(s)
I think all hardware is good enough, except for the graphics card: better use a dedicated graphics card from Nvidia.
Thanks for the answer.
But is possible realize a system with live streaming through 3 input video with this configuration?
And also the RAM is DDR4, is this a problem?
Thanks!
ByProgrammer wrote:Thanks for the answer.
Thanks! It should be good enough for 3 camera's, if you use a dedicated gpu. Especially with hardware encoding (nvidia) you should be fine. DDR4 should work without any issues.
