ByProgrammer
#1 Posted : Thursday, September 15, 2016 4:07:35 AM(UTC)
ByProgrammer
Hello, my idea is to realize a WebTV.
I want to create a web TV with youtube streaming. I thought of this computer setup, and I wonder if it's okay with your VMix software.
I would use 3 INTENSITY PRO capture devices 4K of BlackMagic Design to connect three video cameras to the computer, but with these components, the computer will be able to withstand all inputs?
Motherboard: Asus Z170-A
Processor: Intel Core i5-6500 3.2 GHz CPU with GPU HD Graphics 530 Boxed
RAM: 16 GB DDR4
HDD: 240 GB SSD read 560 MB / s and write 530 MB / s
Thanks.
Ittaidv
#2 Posted : Thursday, September 15, 2016 10:22:07 AM(UTC)
Ittaidv
I think all hardware is good enough, except for the graphics card: better use a dedicated graphics card from Nvidia.
ByProgrammer
#3 Posted : Thursday, September 15, 2016 4:31:46 PM(UTC)
ByProgrammer
Thanks for the answer.
But is possible realize a system with live streaming through 3 input video with this configuration?
And also the RAM is DDR4, is this a problem?
Thanks!
Ittaidv
#4 Posted : Thursday, September 15, 2016 4:39:38 PM(UTC)
Ittaidv
Thanks!
It should be good enough for 3 camera's, if you use a dedicated gpu. Especially with hardware encoding (nvidia) you should be fine.
DDR4 should work without any issues.
ByProgrammer
#5 Posted : Thursday, September 15, 2016 4:41:28 PM(UTC)
ByProgrammer
Ok Thanks!
