Murchik
#1 Posted : Tuesday, September 13, 2016 3:48:55 PM(UTC)
Murchik
Ukraine
Hello. Excuse if to wrong quarter and for translation - I use translator.
Question - Vmix pro 16 64x. There is possibility to write down video with the multichannel inlaid sound (for example Grass Valley HQX 16 ch. audio) appointing necessary entrance for a record. Tried different variants - written down only 2 ch stereo. Prompt me how to influence?
Used all variants. A record goes only stereo 2 channels.
Murchik attached the following image(s):
Inputs set.png (168kb) downloaded 1 time(s).
Capture assorty.png (173kb) downloaded 2 time(s).
Ittaidv
#2 Posted : Wednesday, September 14, 2016 5:41:21 AM(UTC)
Ittaidv
Right now Vmix only supports the recording of a stereo audio recording. You need additional hardware, such as a AJA kipro to solve this.
Murchik
#3 Posted : Wednesday, September 14, 2016 5:49:52 AM(UTC)
Murchik
Ukraine
sadly, very sadly, this function is so needed
Peter B
#4 Posted : Wednesday, September 14, 2016 7:07:53 AM(UTC)
Peter B
There are the A and B audio busses that currently appear on your sound card outputs that
could be recorded separately.
There was a feature request regarding embedding these on SDI -
http://forums.vmix.com/d....aspx?g=posts&t=6666
Murchik
#5 Posted : Wednesday, September 14, 2016 7:28:42 AM(UTC)
Murchik
Ukraine
it requires acquisition of new equipment, what money already did not remain on. I hoped that was distribution system on audio to the map of codec.
For example as in Edius 7
Default map.png (72kb) downloaded 2 time(s).
custom map.png (74kb) downloaded 2 time(s).
Murchik
#6 Posted : Wednesday, September 14, 2016 3:39:22 PM(UTC)
Murchik
Ukraine
Possible is sense except Mulicorder video to add the option of Mulicorder audio on entrances for separate capture of every entrance channel. As one of variants of decision of problem for further work by a record.
