Help for multichannel capture sound
Joined: 9/13/2016(UTC) Posts: 112   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
Hello. Excuse if to wrong quarter and for translation - I use translator. Question - Vmix pro 16 64x. There is possibility to write down video with the multichannel inlaid sound (for example Grass Valley HQX 16 ch. audio) appointing necessary entrance for a record. Tried different variants - written down only 2 ch stereo. Prompt me how to influence? Used all variants. A record goes only stereo 2 channels.  Murchik attached the following image(s):  Inputs set.png (168kb) downloaded 1 time(s). Capture assorty.png (173kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
Joined: 12/19/2013(UTC) Posts: 600   Location: Belgium Thanks: 75 times Was thanked: 91 time(s) in 75 post(s)
Right now Vmix only supports the recording of a stereo audio recording. You need additional hardware, such as a AJA kipro to solve this.
Ittaidv wrote:Right now Vmix only supports the recording of a stereo audio recording. You need additional hardware, such as a AJA kipro to solve this. sadly, very sadly, this function is so needed
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
it requires acquisition of new equipment, what money already did not remain on. I hoped that was distribution system on audio to the map of codec. For example as in Edius 7 Murchik attached the following image(s):  Default map.png (72kb) downloaded 2 time(s). custom map.png (74kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
Possible is sense except Mulicorder video to add the option of Mulicorder audio on entrances for separate capture of every entrance channel. As one of variants of decision of problem for further work by a record. Murchik attached the following image(s):  multi.png (542kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
