tdurhamjr
#1 Posted : Tuesday, September 13, 2016 2:52:10 PM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
Goal: To stream to one service starting at a particular time (ie 10:15 am). Then start streaming to YouTube at a later time (ie 10:45 am).
Once we start streaming our church service, I want to stream the sermon portion to Youtube which will be a later time. Does anyone have a solution for starting the youtube stream at that specific time without stopping the current live stream?
jip
#2 Posted : Tuesday, September 13, 2016 5:10:48 PM(UTC)
jip
Estonia
vMix video output can be used in different streaming encoders, even within one computer with sufficient power.
From vMix, you can start the stream to one channel, with a standalone Adobe Flash Media Live Encoder into anorher, and perhaps with OBS to a third service. This will require a considerable grunt from the computer and sufficient outbound bandwidth.
tdurhamjr
#3 Posted : Tuesday, September 13, 2016 5:28:26 PM(UTC)
tdurhamjr
Thanks! I will give that a try. I have the power and the bandwidth :)
Ittaidv
#4 Posted : Wednesday, September 14, 2016 5:34:54 AM(UTC)
Ittaidv
We use restream.io for this.
In order to do this however, you will need to cut your livestream for a few seconds every time when you add another channel to stream to. But in my opinion it's the best option, since it doesn't require additional recourses and bandwidth.
