Im trying to figure out a way to create a squeeze back. What would essentailly be a picture in picture. Would like to resize the output with a graphic underneath. Attached is an example. Anyone have any ideas how I can achieve this. Ant  Anthonie02 attached the following image(s):  exm.png (836kb) downloaded 19 time(s).You cannot view/download attachments. Try to login or register.
Multiview (of image input): put video on top of image and resize and move
Is there any way to animate it in and out?
Use "Merge" transition. ex. video active while multiview is preview or vice versa
Thanks for your help works perfectly.
@ Anthonie02 Some quick references for you on the above advice: http://www.vmix.com/help...dex.htm?MergeEffect.htmlThe Merge Transition can have some quirks to it so it's a good idea to play around with things to get a good understanding, but for the simple "squeeze back" that you seek, there should be no issue. Ice
