Anthonie02
#1 Posted : Wednesday, September 7, 2016 7:03:35 AM(UTC)
Anthonie02
Im trying to figure out a way to create a squeeze back. What would essentailly be a picture in picture.
Would like to resize the output with a graphic underneath. Attached is an example.
Anyone have any ideas how I can achieve this.
Ant
Anthonie02 attached the following image(s):
#2 Posted : Wednesday, September 7, 2016 7:32:42 AM(UTC)
Was thanked: 1017 time(s) in 835 post(s)
Multiview (of image input): put video on top of image and resize and move
Anthonie02
#3 Posted : Wednesday, September 7, 2016 8:20:44 AM(UTC)
Anthonie02
Is there any way to animate it in and out?
#4 Posted : Wednesday, September 7, 2016 8:45:42 AM(UTC)
Use "Merge" transition. ex. video active while multiview is preview or vice versa
Anthonie02
#5 Posted : Wednesday, September 7, 2016 9:31:43 AM(UTC)
Anthonie02
Thanks for your help works perfectly.
#6 Posted : Wednesday, September 7, 2016 9:32:37 AM(UTC)
@ Anthonie02
Some quick references for you on the above advice:
http://www.vmix.com/help...dex.htm?MergeEffect.html
The Merge Transition can have some quirks to it so it's a good idea to play around with things to get a good understanding, but for the simple "squeeze back" that you seek, there should be no issue.
