Clean rec (without overlay) and stream with overlay
Thanks: 1 times Was thanked: 6 time(s) in 5 post(s)
Hello all,
I can't find configuration for clean rec(without overlay) and video sream with overlay. Please help if possible config like that.
Thanks for answers. Arturas
@ artciukas
To the best of my knowledge, Recording/Streaming within vMix use the same feed and are inseparable. In order to record a clean feed you will need to use an External recorder of some sort and record a properly configured External or Fullscreen feed from vMix.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
As Ice said you will need to use external 2. You could send this with overlays to an instance or buy a Basic HD version and stream from that. Vmix 1 then records a clean version.
Vmix 2 could record NDI / Ext 2 if on a laptop. It may be easier to buy a recorder.
