Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
desmar wrote:@elgarf
List widget doesn't load data properly, it rearranges data.. see attached pics..
Would like list to look like text file in list menu..
in proper numerical order...
Had the same problem above, but no solution :(
Joined: 11/21/2013(UTC) Posts: 32 Location: Stockholm
Thanks: 2 times Was thanked: 5 time(s) in 5 post(s)
Add in your textfile a zero before 1, 2 so it reads 01,02...
tubbis_2 wrote:Add in your textfile a zero before 1, 2 so it reads 01,02... That's one solution, but it also means it will read 01, 02 and so on in the title aswell. Doesn't look good imo and even if it's possible to remove it manually it should very well be possible to get the same order as in the text file.
This is just another example of me giving an answer without reading the whole topic before. Sorry! I thought the number were just a number to sort the titles and wasn't showing in the actual title. My bad.
tubbis_2 wrote:This is just another example of me giving an answer without reading the whole topic before. Sorry! I thought the number were just a number to sort the titles and wasn't showing in the actual title. My bad.
Don't be sorry, it may not be the case for everyone. But I know in my case at least where I use shirt numbers to sort players it will still be somewhat of a problem as the numbers is something I want to display in the title too. So it would for sure be great if it didn't sort it wrong in the software :)
Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
Hello @elgarf First congratulate you on this excellent application is of tremendous help. The following is ask if you can please make some adjustments that personally I would like to be in the application. 1. Color change in the activation buttons, green and orange if active if inactive. the colors are example you could use any color, the goal is to identify what is active. 2. A video designed to show further how you can use different widget of the application site, or manual.
Thanks for your help and collaboration. Exitos, Exitos, Exitos Apologies for the English, use a translator, I speak Spanish.
Joined: 10/23/2015(UTC) Views messages in topic : 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
Hi, I've removed sorting inside list widget, so you need download last version of controller. JAIRODJ, what you mean in "activation buttons" phrase? I've started writing manual, but it's not ready yet. Maybe @coropratejames or somebody else can do base, which I fill with info. Still no time to shot videos. I'm working on Data Source property for list widget (It can take data from any widget by it's name and property name), but it's not ready yet. Firts post
 2 users thanked elgarf for this useful post.
@elgarf keep up the good work. Will see how I go in a week or two. A little tied up this week. But happy to do a quick video if that helps. The UTC has worked great last 3 games.
hi @elgarf Thanks again for your work I mean when the button is pressed to Enable the function, change color. Green - Enabled / On Orange or (No color) - Off / Off You can see that function is ON or OFF The image is an example
 1 user thanked JAIRODJ for this useful post.
Joined: 9/13/2016(UTC) Posts: 5 Location: christian-ls
Hi guys have you seen this software? www.live-score-app.comscorebug software with additional iOS remote controls cheers
elgarf wrote:Are you sure you have Functions.xml in program folder? Yes - functions.xml is present. Still not scripts present and the mapping is all over the place. Controller was initially created on another computer.
@moth, you can share log from your documents/vmix UTC, I'll look at this.
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
I try this for first time tonight. Great controller elgarf
I figure it out and manage to deal with yellow, red cards and substitutions with list widget. I can in 4-5 minutes copy paste numbers and player names from my title editor where I have graphics with player list (vMix exports it like .csv with "" and , delimiters) and insert it in UTC list, than just copy it for red, yellow and substitutions and thats it. Works great.
The only problem that I have is that i don't see symbols/icons on widgets (x,save, + etc). DO I need to download some font or what? I have Win7.
I will put printscreen of UTC if I don't forget, I have live stream on wednesday
Thank you Marko
@Siroki You need Segoe UI Symbol font from win 10.
elgarf wrote:@Siroki You need Segoe UI Symbol font from win 10. Can you please put it on first topic for download from your PC? thx Marko
Today I was working with UTC that I configure yesterday. It worked ok after setup, before game and some time during the game but in some point it brokes down and mix titles. I have 3 drop down lists with player names. One for yellow card, one for red and one for scorer + 2 dropdows for substition in and out. One set of this is on left fot Home team and another set is on right for Guest team In some point during the second half yellow card for home team starts showing the guest team titles ... I locked the modules in menu BTW its great controler no matter I have small problems Here is the recorded game: https://www.youtube.com/watch?v=s68qso7l5tUBest regards Marko
@Siroki, maybe you added input during game, and forgot to update state?
elgarf wrote:@Siroki, maybe you added input during game, and forgot to update state? I can't remember but that inputs that I use from UTC I didn't touch. Maybe I made some mistakes, click something that mix it up. I will do the next game and try again, I have everything saved. I forgot to make printscreen but I will try to do that next time so you can see my configuration. I was wondering something. The scorer name I have list loaded like for yellow, red card etc The list that I make before game. I have scoreboard that has special lines Home score, Guest score..I was wondering can I combine list dropdown with names, and something other to pick up the score. So when there is a goal I push +1 for home team and my scoreboard says 1:0, now I go to UTC and from dropdown I pick the scorer name and I need to type manual the score 1:0 near scorer name and release it. That takes time so I can't get ecerything on time. It would be great if I can just go to +1 goal and pick a scorer name and that my title shows the scorer name and score (but the score is picked from scoreboard)? thx best regards Marko
Siroki wrote:elgarf wrote:@Siroki, maybe you added input during game, and forgot to update state? I can't remember but that inputs that I use from UTC I didn't touch. Maybe I made some mistakes, click something that mix it up. I will do the next game and try again, I have everything saved. I forgot to make printscreen but I will try to do that next time so you can see my configuration. I was wondering something. The scorer name I have list loaded like for yellow, red card etc The list that I make before game. I have scoreboard that has special lines Home score, Guest score..I was wondering can I combine list dropdown with names, and something other to pick up the score. So when there is a goal I push +1 for home team and my scoreboard says 1:0, now I go to UTC and from dropdown I pick the scorer name and I need to type manual the score 1:0 near scorer name and release it. That takes time so I can't get ecerything on time. It would be great if I can just go to +1 goal and pick a scorer name and that my title shows the scorer name and score (but the score is picked from scoreboard)? thx best regards Marko Seems like you already have the score sent to different scoreboards, don't you? You've got the top left one and bottom middle one. Just add one more title which updates when the score is updated, shouldn't that be enough? You still would have to pick the scorer manually, but not the score.
Jedda wrote:Siroki wrote:elgarf wrote:@Siroki, maybe you added input during game, and forgot to update state? I can't remember but that inputs that I use from UTC I didn't touch. Maybe I made some mistakes, click something that mix it up. I will do the next game and try again, I have everything saved. I forgot to make printscreen but I will try to do that next time so you can see my configuration. I was wondering something. The scorer name I have list loaded like for yellow, red card etc The list that I make before game. I have scoreboard that has special lines Home score, Guest score..I was wondering can I combine list dropdown with names, and something other to pick up the score. So when there is a goal I push +1 for home team and my scoreboard says 1:0, now I go to UTC and from dropdown I pick the scorer name and I need to type manual the score 1:0 near scorer name and release it. That takes time so I can't get ecerything on time. It would be great if I can just go to +1 goal and pick a scorer name and that my title shows the scorer name and score (but the score is picked from scoreboard)? thx best regards Marko Seems like you already have the score sent to different scoreboards, don't you? You've got the top left one and bottom middle one. Just add one more title which updates when the score is updated, shouldn't that be enough? You still would have to pick the scorer manually, but not the score. Yes, I was thinking about that
