Steadirob
#1 Posted : Saturday, October 13, 2012 4:21:20 AM(UTC)
Steadirob
here is a (new?) request.
Would it be possible to arrange the order of the input frames by dragging them where I want?
I can see a need for re-arranging to priority as the program or workflow continues.
Rob
guztavo
#2 Posted : Saturday, October 13, 2012 8:32:36 AM(UTC)
guztavo
Steadirob,
You can move inputs clicking on the image and dragging where you want.
Regards!
Steadirob
#3 Posted : Saturday, October 13, 2012 11:27:09 PM(UTC)
Steadirob
Really? I tried that yesterday several times, clicking on the image or on the colored bar but nothing moved..... I will try again tomorrow when on the job.
Thanks for thectip.
Rob
guztavo
#4 Posted : Sunday, October 14, 2012 3:04:54 PM(UTC)
guztavo
Hi Rob!
You have to drag from the input (not the color bar, you have to do over the content), and drop over the new place.
Regards!!
Steadirob
#5 Posted : Tuesday, October 16, 2012 8:39:19 AM(UTC)
Steadirob
Ah, I found the way to do this, though it seems to me a bit illogical: Click and drag ON TOP of another input which will then shift away. That feels strange but I can get used to that.
Thanks,
Rob
