Joined: 8/23/2012(UTC) Views messages in topic : 71 Location: Bangkok
here is a (new?) request.
Would it be possible to arrange the order of the input frames by dragging them where I want? I can see a need for re-arranging to priority as the program or workflow continues.
Rob
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Steadirob,
You can move inputs clicking on the image and dragging where you want. Regards!
Really? I tried that yesterday several times, clicking on the image or on the colored bar but nothing moved..... I will try again tomorrow when on the job. Thanks for thectip.
Rob
Hi Rob!
You have to drag from the input (not the color bar, you have to do over the content), and drop over the new place.
Regards!!
Ah, I found the way to do this, though it seems to me a bit illogical: Click and drag ON TOP of another input which will then shift away. That feels strange but I can get used to that.
Thanks,
Rob
