ELCHAPIN
#1 Posted : Sunday, November 21, 2010 12:22:10 AM(UTC)
ELCHAPIN
Hello
PIP screen wil do we put on display
treatment to mesclar but does not work, the mesclar clears the other.
I have problems placing QUICK PLAYER
loop in the overlay function
Not running is paused or stop
#2 Posted : Sunday, November 21, 2010 3:37:44 AM(UTC)
Was thanked: 4788 time(s) in 1643 post(s)
I am having difficulty understanding the issue.
If you are using a translator it may have mixed it up a bit.
If possible, try explaining the issue differently and I will see if I can help.
#3 Posted : Sunday, November 21, 2010 5:59:35 AM(UTC)
There is a known issue with some QuickTime videos not looping properly, is that the issue you are seeing?
If so it will be fixed in v9.
ELCHAPIN
#4 Posted : Sunday, November 21, 2010 4:14:41 PM(UTC)
ELCHAPIN
If correct, that is the problem are Quictime mov files.
As I can put image over another image 2 videos
to mixi at the same time.
use google translator.
Thank you
always support
