Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
Hello PIP screen wil do we put on display treatment to mesclar but does not work, the mesclar clears the other.
I have problems placing QUICK PLAYER loop in the overlay function Not running is paused or stop
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4740 time(s) in 1626 post(s)
I am having difficulty understanding the issue. If you are using a translator it may have mixed it up a bit.
If possible, try explaining the issue differently and I will see if I can help.
Martin vMix
There is a known issue with some QuickTime videos not looping properly, is that the issue you are seeing? If so it will be fixed in v9.
admin wrote:There is a known issue with some QuickTime videos not looping properly, is that the issue you are seeing? If so it will be fixed in v9. If correct, that is the problem are Quictime mov files. As I can put image over another image 2 videos to mixi at the same time. use google translator. Thank you always support
