When I first add instant replay as input the format options are locked 1920 X1080 NTSC 59.94i are locked and I get no drop down options. I can select Mbs.
This is causing one of my cameras to shudder on replay. Any ideas, thanks
Joined: 7/23/2013(UTC) Posts: 136  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
If you use a pre-existing folder for Replay data, you cannot change the format afterwards. Try creating a new folder for the instant replay..?
 1 user thanked jip for this useful post.
Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
Or just empty the folder you use, also works.
 1 user thanked Jedda for this useful post.
