butternut
#1 Posted : Monday, August 22, 2016 4:03:10 PM(UTC)
butternut
When I first add instant replay as input the format options are locked 1920 X1080 NTSC 59.94i are locked and I get no drop down options. I can select Mbs.
This is causing one of my cameras to shudder on replay. Any ideas, thanks
jip
#2 Posted : Tuesday, August 23, 2016 10:32:35 AM(UTC)
jip
Estonia
If you use a pre-existing folder for Replay data, you cannot change the format afterwards. Try creating a new folder for the instant replay..?
thanks 1 user thanked jip for this useful post.
stigaard on 8/28/2016(UTC)
Jedda
#3 Posted : Wednesday, August 24, 2016 9:07:42 AM(UTC)
Jedda
Or just empty the folder you use, also works.
thanks 1 user thanked Jedda for this useful post.
