peterpan
#1 Posted : Thursday, August 18, 2016 9:51:34 AM(UTC)
peterpan
Is it possible to take a 4K picture, crop it to 4 zoomed 1080 cameras. Basically use one 4k camera to behave like it was 4 cameras inside Vmix? I know livestream has this function and I´m choosing between these two systems.
They also use this function on the Mevo system
desmar
#2 Posted : Thursday, August 18, 2016 10:40:18 AM(UTC)
desmar
Canada
Yes you can with 4K and pro edition of vMix..
Add camera as input and create 4 virtual inputs
and crop and zoom accordingly..
Only thing, there is no automatic way of doing this at the moment..
thanks 1 user thanked desmar for this useful post.
peterpan on 8/18/2016(UTC)
sinc747
#3 Posted : Thursday, August 18, 2016 10:52:53 AM(UTC)
sinc747
Rank:: Advanced Member
The beauty of vMix, of course, is you can take the 4K camera image, create a virtual input and crop it to 1920x1080 (or any other size)... any portion of the screen, even overlapping portions.
peterpan
#4 Posted : Thursday, August 18, 2016 11:52:45 AM(UTC)
peterpan
Ahh! Great! checked Vmix forums but did not find any info, neither on any of Vmix Videos on youtube.
Think this actually should be promoted and focused on.
Nice feature would be to have smooth-panning between different areas of the 4k video
also and it would be a killer function.
Suddenly 4k cameras is da shit in streaming ;)
#5 Posted : Thursday, August 18, 2016 2:03:41 PM(UTC)
@ peterpan
Experiment with the "Merge" Transition for "smooth-panning between different areas".
peterpan
#6 Posted : Thursday, August 18, 2016 5:33:24 PM(UTC)
peterpan
@iceStream
I´ll try it out, maybe in a future update of Vmix panning will be available.
Seems like a core function when you see the possibilities.
#7 Posted : Thursday, August 18, 2016 6:07:08 PM(UTC)
@ peterpan
It's the same principle that is used in a "Virtual Set".
If you select your camera Input as your background, you can pan/zoom or cut to a preset area of the screen.
A recent "Showcase" thread has some video links that illustrates this fairly well:
http://forums.vmix.com/d....aspx?g=posts&t=6773
The same functionality should engage if you make several "Virtual" copies of your original Input (which you can zoom/crop as desired) and "Merge" between them.
alexandru.ort
#8 Posted : Friday, August 19, 2016 5:24:12 AM(UTC)
alexandru.ort
Hi!
By cropping and zooming as you described in previous posts and having the output set to 1080p, the zoom is done from the 4k stream preserving the quality or from the 1080p output?
Thanks.
Alex
peterpan
#9 Posted : Friday, August 19, 2016 3:33:40 PM(UTC)
peterpan
@alexandra.ort
Yes I meant to preserve the quality from 4k and panning and zooming inside the 4k picture with prserved quality.
look at this video to see what i mean.
kamal
#10 Posted : Friday, August 19, 2016 6:07:15 PM(UTC)
kamal
@peterpan
You could achieve this in vMix by using Virtual Set.
Insert a Blank Virtual Set, click on Setup and use your 4K input as a background. Click on Camera then right click on each of the 4 windows to set your zooming and panning. Also you could insert another Virtual Set with the same 4K input as a background and set another zooming and panning area. Also, try Merge transition with it.
Psing
#11 Posted : Sunday, August 28, 2016 11:12:29 AM(UTC)
Psing
To use only 1 4k cam do i need to choose 4k master working resolution in vmix or can i work in 1080i?
If i choose 1080i as working default resolution what happens to the 4k input? It will be downscaled before or after the virtual croping?
mjgraves
#12 Posted : Sunday, August 28, 2016 2:33:35 PM(UTC)
mjgraves
No. The 4k input is available to be cropped into the 1080 scene.
I've done something similar using a 720p base project with 1080p cameras.
RobLambert
#13 Posted : Friday, August 18, 2017 5:00:39 PM(UTC)
RobLambert
I know it has been a long time. Please, is this what you guys say is possible to do with vMix? I think so. Just watch the first three minutes.
https://vimeopro.com/new...g-series/video/194050584
Thank you all very much.
Rob
madness
#14 Posted : Thursday, August 24, 2017 9:29:04 PM(UTC)
madness
peterpan wrote:
@iceStream
Check this out...
Done in vmix with a static image, but I do this all the time with USB cameras. Including my Logitech Brio 4k running as 2k camera.
thanks 1 user thanked madness for this useful post.
RobLambert on 8/25/2017(UTC)
