Vmix Social is "not running"
I installed latest version of Vmix and vmix social which comes together with same setup file. I enabled Web controller. Vmix Settings >> "Web Controller >> Enabled ( ticked) port: 8080 I tested the http://local_ip:8080 from web browser. it's working, and I can control the vmix from browser interface.
But when I open the Vmix Social , Vmix Social says "Not running" So I am not able to connect to facebook and twitter etc.
I tried the this operation in two computers which have OS windows10
is there any idea what the my problem is?
Thanks & Regards
Murat
Joined: 10/28/2014(UTC) Posts: 16 Location: Rotherham, UK
Thanks: 34 times Was thanked: 6 time(s) in 4 post(s)
I've been having a same issue with vMix Social not seeing vMix as running. I've tried it on 3 different machines and have the fault on 2 of them. I haven't been able to find anything in particular that has caused the issue on the two machines.
All 3 are running windows 10 64.
Cheers,
Joe
1 user thanked Stavlin for this useful post.
Joined: 3/15/2018(UTC) Posts: 82 Thanks: 5 times Was thanked: 10 time(s) in 8 post(s)
same thing while testing on virtual could machine running windows server 2016 with vmix 21 latest
any help here how to make it run , also vmix not showing any videos on ly sound , i know for video it might be cause no graphic card on virtual , but any solution since vlc and windows media are playing videos notmal
any help please
You have been a member since:: 2/14/2016(UTC) Posts: 107 Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
vMix 21 is beta, so it it possible it has some bugs...
With latest version 20.0.0.54 vMix Social is able to connect...
In vMix 20.0.0.54 web-interface is port 8088 not 8080, in vMix-social it shows port 8089...
Joined: 10/13/2012(UTC) Posts: 1,162 Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
Try turning off all firewalls. If that works, check that Social is being allowed through the firewall.
