mmorlan62
#1 Posted : Wednesday, August 10, 2016 6:57:15 PM(UTC)
mmorlan62
Was thanked: 7 time(s) in 5 post(s)
This is interesting. I rebuilt my vMix system to Win10 and am encountering a new problem with local recording (I haven't tried streaming yet.)
When I display a full-frame .jpg graphic, cross-fading from a live camera, heavy compression artifacts will appear in the recorded file, tearing the lower third of the frame. These artifacts persist after cross-fading back to the live camera. They eventually disappear. This issue doesn't appear in the live display of the switcher.
I've been using variations on this project file for months without issue.
I attached the project file with which I encountered these issues, the first to use with Win10.
Michael
EDIT: More info. I created a simple project with four 1080p graphic images. The compression artifact persists.
EDIT: More. The compression artifacts appear in mp4 recordings but not wmv.
EDIT: Reducing the MP4 data rate delays or eliminates the artifacting. The frequency of artifacts is the same when recording to different drives. (This is the same system I've been using for vMix since 2012.)
EDIT: Here's the log of one of the problem files:
8/9/2016 6:29:29 PM, Version: 17.0.0.106 x64
8/9/2016 6:29:29 PM, Size: 1920x1080
8/9/2016 6:29:29 PM, System: NTSC 29.97p
8/9/2016 6:29:29 PM, Codec: H264
8/9/2016 6:29:29 PM, Format: UYVY 16 1498831189
8/9/2016 6:29:29 PM, AudioDevice: vMix Audio
8/9/2016 6:29:29 PM, AudioFormat: 48000 Hz 16 Bit 2 Channels
8/9/2016 6:29:29 PM, AudioDelay: 0
8/9/2016 6:29:29 PM, RestartInterval: 0
8/9/2016 6:29:29 PM, Buffers: 10
8/9/2016 6:29:29 PM, BitRate: 25 Mbps
8/9/2016 6:29:29 PM, AudioBitRate: 160 Kbps
8/9/2016 6:29:30 PM, StartRecording
8/9/2016 6:29:50 PM, StopRecording
8/9/2016 6:29:50 PM, Duration: 00:00:21
8/9/2016 6:29:50 PM, Frames: 626
8/9/2016 6:29:50 PM, DroppedFrames: 0
8/9/2016 6:29:50 PM, DueToSourceFrameRate: 0
8/9/2016 6:29:50 PM, DueToHardDiskOrCPU: 0
8/9/2016 6:29:50 PM, DroppedSamples: 0
8/9/2016 6:29:50 PM, MissedSamples: 0
8/9/2016 6:29:50 PM, SyncedSamples: 0
8/9/2016 6:29:50 PM, AudioOffset: 0
8/9/2016 6:29:50 PM, AudioDelay: 100
8/9/2016 6:29:50 PM, AudioEngine
8/9/2016 6:29:50 PM, Running: True
8/9/2016 6:29:50 PM, SampleRate: 48000hz 16 Bit
8/9/2016 6:29:50 PM, MixingErrors: 0
8/9/2016 6:29:50 PM, Streams
8/9/2016 6:29:50 PM, Mixer
8/9/2016 6:29:50 PM, Samples: 24908
8/9/2016 6:29:50 PM, Dropped: Read 0 Write 0
8/9/2016 6:29:50 PM, Latency: 0 ms
8/9/2016 6:29:50 PM, Errors: 0
8/9/2016 6:29:50 PM, Headphones
8/9/2016 6:29:50 PM, Latency: 50 ms
8/9/2016 6:29:50 PM, FFMpeg
8/9/2016 6:29:50 PM, Samples: 102
8/9/2016 6:29:50 PM, Latency: 1020 ms
8/9/2016 6:29:50 PM, Samples: 100
8/9/2016 6:29:50 PM, Latency: 1000 ms
EDIT: The FFMPG MP4 recording has no problems.
EDIT: This could be caused by incorrect SATA drivers for my motherboard.
M
File Attachment(s):
2016-08-05_wh_ep67.zip (15kb) downloaded 3 time(s).
vmix config.zip (7kb) downloaded 1 time(s).
#2 Posted : Thursday, August 11, 2016 7:05:32 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Do you have an AMD graphics card by any chance?
I have seen problems with their H264 hardware encoder on their cards, so unticking "Use hardware encoder" in the MP4 recording settings should resolve it.
mmorlan62
#3 Posted : Thursday, August 11, 2016 8:43:42 AM(UTC)
mmorlan62
I do and have used it and its predecessors for years. I don't remember how I had that "hardware render" checked in the Win7 incarnation. I'll uncheck and try it out.
Just one more reason to go with nVidia. :-/
Thanks,
M
mmorlan62
#4 Posted : Thursday, August 11, 2016 9:22:47 PM(UTC)
mmorlan62
Yep, turning off hardware render fixed the problem.
Thanks!
Michael
