2 Pages12>
color1981
#1 Posted : Friday, February 21, 2014 8:03:23 AM(UTC)
color1981
Hello everyone,
I'm trying to install a streaming video infrastructure with IP cameras. Vmix properly supports the IP camera D-Link DCS-5222L (via rtsp :/ / 192.168.0.101/play1.sdp) but I can not view FOSCAM FI9821W IP camera (via rtsp :/ / admin: admin@192.168.0.102: 80/videoMain).
I know that the rtsp address is correct since it works with VLC.
From other posts I downloaded "rtspinformation.exe" and the response was:
RTSP/1.0 401 Unauthorized
CSeq: 1
Date: Thu, February 20 2014 12:00:07 GMT
WWW-Authenticate: Digest realm = "LIVE555 Streaming Media", nonce = "eaec34a50e84e77372724d3021270aa3"
How can I fix the problem?
Jagawave
#2 Posted : Saturday, February 22, 2014 4:49:15 PM(UTC)
Jagawave
Interesting to hear about the D LINK cam in vmix..Does sound stream ok to vmix with that also..or is it just video?
I hope you get the foscam working
color1981
#3 Posted : Sunday, February 23, 2014 5:03:44 AM(UTC)
color1981
I managed to capture only the video signal. The sound I think is on a separate channel and do not know how to configure it on Vmix.
thanks 1 user thanked color1981 for this useful post.
Jagawave on 2/25/2014(UTC)
nlitend1
#4 Posted : Monday, February 24, 2014 3:08:30 PM(UTC)
nlitend1
color1981 wrote:
Hi, i'm getting the exact same error as you with my foscam 9821w V2. How did you get the video stream working?
Thanks,
nlitend1
color1981
#5 Posted : Monday, February 24, 2014 3:22:32 PM(UTC)
color1981
I got to see the video signal only with vlc. If I can not I'll have to switch to other software.
nlitend1
#6 Posted : Monday, February 24, 2014 3:31:36 PM(UTC)
nlitend1
Thanks for your quick reply. Yes, VLC works fine for me as well.
I cannot get the stream in vmix to connect to the Foscam. I have a feeling that it's because the Foscam username/password is encrypted and vmix does not seem to have an option for sensing for encryption of the password.
color1981
#7 Posted : Monday, February 24, 2014 3:39:02 PM(UTC)
color1981
I do not know if the error is the password access. I tried to delete the password from the menu Foscan, but still can not capture the signal.
chromazone
#8 Posted : Saturday, May 31, 2014 1:22:19 PM(UTC)
chromazone
color1981 wrote:
Hello everyone,
CSeq: 1
Hello!
Reading elsewhere on this forum someone asked the question could vMix add username and password to the rtsp
links. I think that that is the problem with the Foscam 9821w. I have one (the v2) and I kept getting 401 not authorised error.
So what you can do is using VLC is restream and remove the need for a username and password.
Open the rtsp file from the foscam in VLC and then in the media menu select STREAM or press ctrl-s.
In this 'Open Media' Menu select the network tab.
Paste in your foscam rtsp stream eg.
rtsp://192.168.Y.Y:88/videoMain
Click on the Stream button in the bottom corner
A Wizard will pop up (VLC 2.1) and you should see the foscam ip in the source dialog box.
On the next page 'Destination setup' select rtsp (you can leave the display locally option unchecked for better cpu usage).
Next page set you port number (it defaults to 8554)
in the the path box you can set what you like so I put
/stream
Next page UNSELECT the activate transcoding
in profile choose
video h264 + MP3 (MP4)
Now your rtsp converted stream should be
rtsp://192.168.X.X:8554/stream
Remember 192.168.x.x is the address of the machine running VLC NOT the foscam which is 192.168.y.y
USER and Password removed...
This works for me in Vmix 12
I'm surprised someone from vMix hasn't jumped in here, will they change that in the program?
#9 Posted : Tuesday, June 3, 2014 7:16:27 AM(UTC)
Was thanked: 4739 time(s) in 1626 post(s)
I'm looking into adding an additional authentication method to support these cameras.
If someone is able to put up a public rtsp address for their camera that would really help!
chromazone
#10 Posted : Tuesday, June 3, 2014 8:20:51 PM(UTC)
chromazone
Hello Martin,
This is a good page to pick up recent working streams (note they are marked in blue, the red ones don't work)
http://www.vlctest.eu.pn/
I tested the stream below just now (see date of post) and when I pop it into vMix 12.0.0.129(X64) it reported an error.
Yet if I use VLC to restream it (using above method) then it works great!!!
[url=rtsp://l125.polwizjer.com:1935/pl/2014tvcanalplussport]rtsp://l125.polwizjer.com:1935/pl/2014tvcanalplussport[/url]
Foscam run a number of http streams from their site which require user/pass combos but may not be of any use to you.
http://www.foscam.com/links.aspx
I'm sure if you told them what you were trying to do they might post a rtsp stream for you requiring a username/psswd!
I have a few people interested in your solution over wirecast so it would be great if I could show this to them
working. So far the advantage wirecast has over you here is that it can automatically pick up a ONVIF camera.
I'm running Win 8.1 Pro With an Nvidia GTX 550Ti Card (335.23 drivers)and testing with a Foscam 19821W V2 (ONVIF enabled in recent firmware) which can only have a user/pass combo!
Please let me know if I can help you out here. I don't have a public rtsp stream for you but I could schedule one (maybe) if you let me know.
#11 Posted : Wednesday, June 4, 2014 3:38:43 AM(UTC)
I've just tested rtsp://l125.polwizjer.com:1935/pl/2014tvcanalplussport in vMix 12 and it is working fine.
What I need is an rtsp stream that requires a username and password for testing.
chromazone
#12 Posted : Wednesday, June 4, 2014 8:07:44 PM(UTC)
chromazone
Hello Martin,
Sorry I just realised I had added rtsp://l125.polwizjer.com:1935/pl/2014tvcanalplussport
as an rtsp over udp rather than rtsp over tcp
I tried to set up my camera to give you remote access however with my current setup I can't port forward.
I might be able to borrow a different modem and see if that will work.
Nav
#13 Posted : Wednesday, July 9, 2014 7:31:26 AM(UTC)
Nav
I wonder if there is any update regarding this?
I am looking to get a Foscam FI9826W - does anyone have any experience with this?
On a wider note it would be good to have a list of IP cameras which are known to work reliably with Vmix. Something similar to the "Supported Hardware" page.
Regards
Nav
chromazone
#14 Posted : Friday, July 11, 2014 11:49:43 AM(UTC)
chromazone
Hi Nav,
With regards to Foscam and cameras requiring a login -
I tried the latest version of vMix as of the time of this post 12.0.0.131 and no, it is not resolved.
cz
thanks 1 user thanked chromazone for this useful post.
Nav on 7/12/2014(UTC)
Nav
#15 Posted : Saturday, July 12, 2014 11:15:42 AM(UTC)
Nav
Thanks Chromazone for the update. Can Martin advise if this is in the pipeline for a fix?
#16 Posted : Saturday, July 12, 2014 11:19:39 AM(UTC)
Please try the latest vMix 13 Beta:
http://forums.vmix.com.a....aspx?g=posts&t=2333
chromazone
#17 Posted : Friday, July 25, 2014 2:26:59 PM(UTC)
chromazone
vMix 13.0.0.140 is working with the FOSCAM FI9821W V2
To access use this syntax
rtsp://user:password@xxx.xxx.xxx.xxx:88/videoMain
Where x is your ip address, user and password as you have set them.
I haven't figured out the correct address to inclue sound so if anyone has any ideas
please post them (/videoMain only gives the video stream I think)
Great work guys!
Ario
#18 Posted : Wednesday, April 1, 2015 6:27:29 AM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
Dear all, I know, this is a rather old thread ....
Still, I am using the Foscam FI9826W with vMix for video, without issues.
Did anyone figure out a way to get audio from the Foscam into vMix ?
Thanks in advance, kind greetings,
Arie
Lennard
#19 Posted : Monday, August 8, 2016 7:44:45 AM(UTC)
Lennard
Dear all,
Like Ario (post above) I still have issues getting a Foscam FI9826P to stream audio. Within VLC player no issues, both video and audio are available.
In VMIX, creating an new RTSP stream to rtsp://user:pass@172.20.x.x:88/videoMain does show video, but no audio.
Is there any solution to this issue?
Thanks in advance,
Lennard
kane
#20 Posted : Monday, August 8, 2016 2:08:41 PM(UTC)
kane
Why not use the NDI VLC plug-in to convert the incoming signal into NDI format and then have vMix 17 (or any other NDI application) receive the signal?
NDI Tools (contains the NDI VLC plug-in): http://pages.newtek.com/...Tools-Pack-Download.html
Kane Peterson
NewTek
Guest (6)
2 Pages12>
