hello everybody.
For the little tv station i work in, i'm going to build up a backup for our Video Toaster.
But i really need some help.
In the office i got: 2 intensity pro PCI-E 1X boards (with no bracket and breakout cable) i get from the "bay" 1 PCI-e 4x Intensity pro 4k (full package).
I got also from the bay an OLD (PCI version) decklink Extreme and a (just a bit newer) decklink extreme 1x PCIE.
now the problem is that black magic cards are quite difficoult with driver versions and motherboards with more than 3 pci express slots are expensives.
Could you suggest me please operating system version (xp? seven?) and what version of blackmagic drivers are better?
Thanks a lot,
Federico Allegretti
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
allegfede wrote:hello everybody.
Thanks a lot,
Federico Allegretti I have Intensity Pro and MiniRecorder from BMD I was trying them on some branded pc's like Lenovo and it didn't work. Now I bought gigabyte and everything works perfect. The MB has 2 x1, 2 x16 slots and I have now ekstra 2 slots free for graphic card or another capture card. Didn't have problems with drivers. I have Win 7 but I installed drivers from CD that I get with cards. That means older drivers worked great for me :) Best regards
thanks for the kind reply.
Trying the setup with all the cards i can arrange in the MB, but i'm quite shure windows 7 will not like the old decklink 7.9 drivers :D
