scottyp
#1 Posted : Thursday, July 28, 2016 11:23:38 PM(UTC)
scottyp
i keep getting an error from youtube no matter how I set it up, we wiped the computer to install the new graphics card and when I was setting everything back up I cant get you tube to stream.
streaming error: problem publishing at primary server FMLE exited
Siroki
#2 Posted : Friday, July 29, 2016 4:14:21 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
You don't put correct settings or you can't stream if you are banned or something like that.
Try some quick free streaming service like:
http://www.micast.tv/
And see will it go
sinc747
#3 Posted : Friday, July 29, 2016 12:23:32 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
First, update vMix to the latest version from the vMix.com website.
Second, in the Stream Settings (the little gear icon to the left of the Stream button at the bottom of the vMix window), select FFMPEG as the Application.
Then, Add a new profile (give it a name), Select Destination as YouTube Live.
Then, go to YouTube.com and log into your account, click My Channel (left column), and then click Video Manager. In the left column, click Live Streaming and scroll down to the Encoder Setup section and copy the Stream/Name Key. Make sure you don't try to write it down.
Then back to vMix Stream Settings and input the Stream Key, click Save & Close and you are ready to stream.
Try this are let us know how it goes.
- Tom
LG
#4 Posted : Sunday, July 31, 2016 7:54:31 AM(UTC)
LG
And see will it go
does not work
i get stream key info but only errors cannot connect
is this still up and running?
Siroki
#5 Posted : Sunday, July 31, 2016 6:50:50 PM(UTC)
Siroki
And see will it go
does not work
I don't know, it worked for me. Maybe servers were down when you tried
