Joined: 1/13/2010(UTC) Posts: 5,369  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
watchfulone wrote: Please Please Please remember to include a Customizable Title Generator with simple animation like we use to change camera shots such as: Fly in/out, Zoom in/out, rotate in/out, slide in/out, fade in/out, scroll in/out,etc. All in/out animations by using the same or similar coding that is already in vMix, so we can input a png or jpeg, tiff, etc. already design with text, graphics, size and have it animate in and out. Pleaseeeeeeeeeeeee.
I would suggest having a look at some of the existing titles in the Titles folder as you can modify the background image of many of them very easily. You can also use the overlay transition effects to achieve what you are after. The possibility of a title generator was considered but it turned out to be a lot of work to build, it's not as easy as you think. As most users preferred to have ready made titles we have decided to concentrate on that and will release an additional titles template pack soon. Regards, Martin vMix
Joined: 8/4/2012(UTC) Posts: 129 Location: the Netherlands
a little bit of perl with imagemagick and the recently added load / close in the API should have your titles ready in no-time :)
that's how we do it anyway (or planning to do it, cause designs aren't ready yet)
M@Ik
Thanks: 2 times Was thanked: 5 time(s) in 5 post(s)
@doyousee.me: if you have anything ready, could you please make it available to us, preferably here in the forums? Sounds really great - and useful! :)
it could be usefull, but it's just 4 lines of code , which you need to customise for your own need, so i'd rather send you on your way with the search terms activeperl and imagemagick and you will find 100 tutorials better than i could ever write .
( i create a webservice, that get's called by a timing system, creates an image and loads that image through the api and displaysit (last 2 steps are to be implemented))
M@ik
