Shortcut key for ticker duration
I'm using a LaunchControlXL midi unit with VMix and it's been plain sailing so far. However, we have a lot of variable length ticker titles and ideally I want to change the duration of the ticker title from the midi controller using a slider during a live broadcast. We would then store multiple ticker text's in the one title and switch between them and adjust each ticker text's duration's so they kept going at a constant speed. However, I can't find one. Can anyone guide me in the right direction? I suppose a workaround would be to have a lot of separate ticker title inputs.
Joined: 5/14/2013(UTC) Posts: 150  Location: uk Thanks: 2 times Was thanked: 27 time(s) in 23 post(s)
I had the same issue when I was feeding the ticker from an external script , the prblem is you don't set a speed but a total duration, I ended up editing the title to show the duration to be set along side the text , then within the php that was feeding in the content I did a character count then set the duration accordingly
 1 user thanked Henny for this useful post.
Joined: 3/7/2012(UTC) Posts: 2,682  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ redpowerstation
Perhaps a "Feature Request" is in order... AFAIK there isn't any means within the API to alter or set the duration of the 'Ticker' playback.
Henny wrote:I had the same issue when I was feeding the ticker from an external script , the prblem is you don't set a speed but a total duration, I ended up editing the title to show the duration to be set along side the text , then within the php that was feeding in the content I did a character count then set the duration accordingly Any code examples of how to access this in the API? Thanks
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Ice Hi Ice i'm looking to bind an image to the end of any text segment in vmix titles i also started vmix web API & can set text or image or visibility but not such thing i found [mytext] [mylogo] [mytext] [mylogo] i also read your previous post there https://forums.vmix.com/...20826-Ticker-with-logo-sit was useful & also find this magic here : but its not RTL Support ! and hope you can help me doing this one
Originally Posted by: redpowerstation  Henny wrote:I had the same issue when I was feeding the ticker from an external script , the prblem is you don't set a speed but a total duration, I ended up editing the title to show the duration to be set along side the text , then within the php that was feeding in the content I did a character count then set the duration accordingly Any code examples of how to access this in the API? Thanks Hi Ice i'm looking to bind an image to the end of any text segment in vmix titles i also started vmix web API & can set text or image or visibility but not such thing i found [mytext] [mylogo] [mytext] [mylogo] i also read your previous post there https://forums.vmix.com/...20826-Ticker-with-logo-sit was useful & also find this magic here : but its not RTL Support ! and hope you can help me doing this one
Joined: 12/27/2012(UTC) Posts: 5,472  Location: Belgium Thanks: 313 times Was thanked: 1013 time(s) in 832 post(s)
Originally Posted by: Winops  Originally Posted by: redpowerstation  Henny wrote:I had the same issue when I was feeding the ticker from an external script , the prblem is you don't set a speed but a total duration, I ended up editing the title to show the duration to be set along side the text , then within the php that was feeding in the content I did a character count then set the duration accordingly Any code examples of how to access this in the API? Thanks Hi Ice i'm looking to bind an image to the end of any text segment in vmix titles i also started vmix web API & can set text or image or visibility but not such thing i found [mytext] [mylogo] [mytext] [mylogo] i also read your previous post there https://forums.vmix.com/...20826-Ticker-with-logo-sit was useful & also find this magic here : but its not RTL Support ! and hope you can help me doing this one How many times are you going to post this all over the place even at places where it is not related even . This will NOT help ! If you have a problem with the app contact the creator !
