redpowerstation
#1 Posted : Monday, July 25, 2016 8:23:15 AM(UTC)
redpowerstation
I'm using a LaunchControlXL midi unit with VMix and it's been plain sailing so far.
However, we have a lot of variable length ticker titles and ideally I want to change the duration of the ticker title from the midi controller using a slider during a live broadcast.
We would then store multiple ticker text's in the one title and switch between them and adjust each ticker text's duration's so they kept going at a constant speed.
However, I can't find one. Can anyone guide me in the right direction?
I suppose a workaround would be to have a lot of separate ticker title inputs.
Henny
#2 Posted : Monday, July 25, 2016 2:58:30 PM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
I had the same issue when I was feeding the ticker from an external script , the prblem is you don't set a speed but a total duration, I ended up editing the title to show the duration to be set along side the text , then within the php that was feeding in the content I did a character count then set the duration accordingly
thanks 1 user thanked Henny for this useful post.
redpowerstation on 7/27/2016(UTC)
#3 Posted : Monday, July 25, 2016 4:23:21 PM(UTC)
@ redpowerstation
Perhaps a "Feature Request" is in order...
AFAIK there isn't any means within the API to alter or set the duration of the 'Ticker' playback.
redpowerstation
#4 Posted : Wednesday, July 27, 2016 1:52:12 AM(UTC)
redpowerstation
Any code examples of how to access this in the API? Thanks
User is suspended until 5/19/2029 2:05:28 PM(UTC) Winops
#5 Posted : Wednesday, August 10, 2022 9:25:50 PM(UTC)
Winops
Argentina
Originally Posted by: IceStream Go to Quoted Post
@ redpowerstation
Hi Ice
i'm looking to bind an image to the end of any text segment in vmix titles
i also started vmix web API & can set text or image or visibility
but not such thing i found
[mytext] [mylogo] [mytext] [mylogo]
i also read your previous post there
https://forums.vmix.com/...20826-Ticker-with-logo-s
it was useful
& also find this magic here :
but its not RTL Support !
and hope you can help me doing this one
#6 Posted : Wednesday, August 10, 2022 9:26:54 PM(UTC)
Winops
Argentina
Hi Ice
it was useful
#7 Posted : Wednesday, August 10, 2022 9:27:55 PM(UTC)
Winops
Argentina
Hi Ice
it was useful
#8 Posted : Wednesday, August 10, 2022 11:55:50 PM(UTC)
Hi Ice
it was useful
How many times are you going to post this all over the place even at places where it is not related even . This will NOT help !
If you have a problem with the app contact the creator !
