Ricky DB
#1 Posted : Sunday, July 24, 2016 10:32:31 AM(UTC)
Ricky DB
Hello.
I'm at the begin with my vMix.
I'll like to try to broadcast to a normal host as Mainstreaming and at the same time to Youtube Live (or Facebook), for increase ours viewrs and also to garantee that the Streaming will still go on in the first Host (Mainstreaming) in case that Youtube blocked the broadcast because of the copyrigth (difficult to undestand how its work...)of musics etc.
Is it possible with vMix? Can i send the same signal for 2 Streamings Host? If yes, please let me know how?
Thank
AElli
#2 Posted : Sunday, July 24, 2016 1:43:45 PM(UTC)
AElli
Not directly from Vmix. With your main stream running within Vmix. Install FMLE or OBS as a separate program to your Vmix stream, configure / enable vMix External Output which provides FMLE /OBS with a feed called vMix Video. Don't forget to grab an audio source as well for the external streaming application.
A.
thanks 1 user thanked AElli for this useful post.
Ricky DB on 7/25/2016(UTC)
richardgatarski
#3 Posted : Sunday, July 24, 2016 1:48:28 PM(UTC)
richardgatarski
I think restream.io will do the trick. (have not used it yet, but search the forum)
corporatejames
#4 Posted : Sunday, July 24, 2016 7:14:22 PM(UTC)
corporatejames
You can stream to 3 CDN's (Destinations) at the same time. If I'm understanding your question right. As you can stream to DaCast for example on your first
then to YouTube followed by Facebook depending on your Bandwidth and PC Specs to handle the encoding.
thanks 1 user thanked corporatejames for this useful post.
Maximus
#5 Posted : Sunday, July 24, 2016 8:18:56 PM(UTC)
Maximus
It can require quite a lot of bandwidth to send 3 streams, especially if they are at HD. An alternative is Wowza on AWS. You can send 1 stream to them and send out more than one output stream using Stream Targets.
Maxi
thanks 1 user thanked Maximus for this useful post.
corporatejames
#6 Posted : Sunday, July 24, 2016 9:10:16 PM(UTC)
corporatejames
Or you can use https://switchboard.live which Tom recently discussed this in his weekly show.
A Stream Becomes 8 Streams. Rudy Ellis of Switchboard Live Shows How
Maximus
#7 Posted : Monday, July 25, 2016 4:34:31 AM(UTC)
Maximus
Interesting find @corporatejames. I will give it try to see what it's like. It appears to only offer RTMP connections, but I usually have to send mpeg ts and rtp streams.
Maxi
Ricky DB
#8 Posted : Wednesday, July 27, 2016 1:26:52 PM(UTC)
Ricky DB
Thank everyone for the Answers.
I'll try this advices and find the best way for me.
Regards.
Ricky
