It's possible Boadcast for 2 Host concurrently?
Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Hello.
I'm at the begin with my vMix.
I'll like to try to broadcast to a normal host as Mainstreaming and at the same time to Youtube Live (or Facebook), for increase ours viewrs and also to garantee that the Streaming will still go on in the first Host (Mainstreaming) in case that Youtube blocked the broadcast because of the copyrigth (difficult to undestand how its work...)of musics etc.
Is it possible with vMix? Can i send the same signal for 2 Streamings Host? If yes, please let me know how?
Thank
Thanks: 2 times Was thanked: 13 time(s) in 12 post(s)
Not directly from Vmix. With your main stream running within Vmix. Install FMLE or OBS as a separate program to your Vmix stream, configure / enable vMix External Output which provides FMLE /OBS with a feed called vMix Video. Don't forget to grab an audio source as well for the external streaming application.
A.
 1 user thanked AElli for this useful post.
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
I think restream.io will do the trick. (have not used it yet, but search the forum)
 1 user thanked richardgatarski for this useful post.
You can stream to 3 CDN's (Destinations) at the same time. If I'm understanding your question right. As you can stream to DaCast for example on your first then to YouTube followed by Facebook depending on your Bandwidth and PC Specs to handle the encoding.
 1 user thanked corporatejames for this useful post.
Joined: 10/25/2012(UTC) Posts: 179 Location: Barbados
It can require quite a lot of bandwidth to send 3 streams, especially if they are at HD. An alternative is Wowza on AWS. You can send 1 stream to them and send out more than one output stream using Stream Targets.
Maxi
 1 user thanked Maximus for this useful post.
Interesting find @corporatejames. I will give it try to see what it's like. It appears to only offer RTMP connections, but I usually have to send mpeg ts and rtp streams.
Maxi
Thank everyone for the Answers.
I'll try this advices and find the best way for me.
Regards.
Ricky
