66 Pages«<34567>»
a4k
#81 Posted : Thursday, July 21, 2016 3:54:03 AM(UTC)
a4k
hello, the software looks good in the videos I've seen. But I could not prove yet, does not connect with my vmix always it stays with the yellow light. Something I'm doing wrong or installation not do it well. windows use 10 Any help? Thank you
sorry for my English by google translator.
elgarf
#82 Posted : Thursday, July 21, 2016 4:34:19 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
When status is yellow, you need to push "Update State" button in menu bar. If it doesn't work, share last log file, located into your documents/vMix UTC/logs.
thanks 1 user thanked elgarf for this useful post.
a4k on 7/21/2016(UTC)
a4k
#83 Posted : Thursday, July 21, 2016 6:50:31 AM(UTC)
a4k
"Update State" does nothing
send file log (Thank you so much for everything):
2016-07-20 10:46:10.4684 INFO Loading mapped functions.
2016-07-20 10:46:10.4884 INFO Loading templates.
2016-07-20 10:46:10.5765 INFO Loading window settings.
2016-07-20 10:46:10.5945 INFO Configuring fabrique to 127.0.1.7:8088.
2016-07-20 10:46:10.5945 INFO Configuring to 127.0.1.7:8088.
2016-07-20 10:46:10.5945 INFO Trying to send function in async mode.
2016-07-20 10:46:10.6896 INFO Async function sended, result is "<vmix><version>17.0.0.105</version><inputs><input key="4f6a60f3-105f-448e-a699-39041b042c6c" number="1" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="0303b0a7-4c83-4031-b184-7482b1e059a3" number="2" type="Blank" title="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Merge" duration="500" /><transition number="2" effect="Cube" duration="1000" /><transition number="3" effect="WipeReverse" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>".
2016-07-20 10:46:10.6896 INFO Creating vMix state form <vmix><version>17.0.0.105</version><inputs><input key="4f6a60f3-105f-448e-a699-39041b042c6c" number="1" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="0303b0a7-4c83-4031-b184-7482b1e059a3" number="2" type="Blank" title="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Merge" duration="500" /><transition number="2" effect="Cube" duration="1000" /><transition number="3" effect="WipeReverse" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>.
2016-07-20 10:46:10.7456 ERROR vMix state not created. System.InvalidOperationException: Error en el documento XML (22, 28). ---> System.InvalidOperationException: Error de validación de instancia: 'WipeReverse' no es un valor válido para TransitionEffect.
en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderState.Read12_TransitionEffect(String s)
en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderState.Read13_Transition(Boolean isNullable, Boolean checkType)
en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderState.Read14_State(Boolean isNullable, Boolean checkType)
en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderState.Read15_vmix()
--- Fin del seguimiento de la pila de la excepción interna ---
en System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
en System.Xml.Serialization.XmlSerializer.Deserialize(Stream stream)
en vMixAPI.State.Create(String textstate)
2016-07-20 10:46:10.7456 INFO Checking vMix server.
2016-07-20 10:46:10.7456 INFO Status changed to Update State.
2016-07-20 10:46:12.6642 INFO Updating state.
2016-07-20 10:46:12.6672 INFO Trying to send function in async mode.
2016-07-20 10:46:12.6672 INFO Async function sended, result is "<vmix><version>17.0.0.105</version><inputs><input key="4f6a60f3-105f-448e-a699-39041b042c6c" number="1" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="0303b0a7-4c83-4031-b184-7482b1e059a3" number="2" type="Blank" title="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Merge" duration="500" /><transition number="2" effect="Cube" duration="1000" /><transition number="3" effect="WipeReverse" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>".
2016-07-20 10:46:12.6672 INFO Creating vMix state form <vmix><version>17.0.0.105</version><inputs><input key="4f6a60f3-105f-448e-a699-39041b042c6c" number="1" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="0303b0a7-4c83-4031-b184-7482b1e059a3" number="2" type="Blank" title="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Merge" duration="500" /><transition number="2" effect="Cube" duration="1000" /><transition number="3" effect="WipeReverse" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>.
2016-07-20 10:46:12.6672 ERROR vMix state not created. System.InvalidOperationException: Error en el documento XML (22, 28). ---> System.InvalidOperationException: Error de validación de instancia: 'WipeReverse' no es un valor válido para TransitionEffect.
2016-07-20 10:46:12.6822 INFO Checking vMix server.
2016-07-20 10:46:13.8242 INFO Updating state.
2016-07-20 10:46:13.8242 INFO Trying to send function in async mode.
2016-07-20 10:46:13.8242 INFO Async function sended, result is "<vmix><version>17.0.0.105</version><inputs><input key="4f6a60f3-105f-448e-a699-39041b042c6c" number="1" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="0303b0a7-4c83-4031-b184-7482b1e059a3" number="2" type="Blank" title="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Merge" duration="500" /><transition number="2" effect="Cube" duration="1000" /><transition number="3" effect="WipeReverse" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>".
2016-07-20 10:46:13.8242 INFO Creating vMix state form <vmix><version>17.0.0.105</version><inputs><input key="4f6a60f3-105f-448e-a699-39041b042c6c" number="1" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="0303b0a7-4c83-4031-b184-7482b1e059a3" number="2" type="Blank" title="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Merge" duration="500" /><transition number="2" effect="Cube" duration="1000" /><transition number="3" effect="WipeReverse" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>.
2016-07-20 10:46:13.8242 ERROR vMix state not created. System.InvalidOperationException: Error en el documento XML (22, 28). ---> System.InvalidOperationException: Error de validación de instancia: 'WipeReverse' no es un valor válido para TransitionEffect.
2016-07-20 10:46:13.8242 INFO Checking vMix server.
2016-07-20 10:46:13.8391 INFO Checking vMix server.
2016-07-20 10:46:22.9746 INFO New text field widget added.
2016-07-20 10:46:22.9746 INFO Opening properties for widget .
2016-07-20 10:46:27.1651 INFO Properties updated.
2016-07-20 10:46:27.9842 INFO Saving templates.
2016-07-20 10:46:27.9842 INFO Saving window settings.
elgarf
#84 Posted : Thursday, July 21, 2016 7:00:32 AM(UTC)
elgarf
Russian Federation
Okay, that was my fault.
Now it should be fixed, please download new version from the first post.
First post
a4k
#85 Posted : Thursday, July 21, 2016 9:54:01 AM(UTC)
a4k
First post
And it works perfect.
Thank you very much, it has been very quick to offer solution.
The donation is well-deserved.
anselm
#86 Posted : Sunday, July 24, 2016 8:03:07 PM(UTC)
anselm
Was thanked: 4 time(s) in 1 post(s)
Download free vMix titles here https://github.com/aezumezu/vMix-Titles
#87 Posted : Monday, July 25, 2016 9:39:05 PM(UTC)
@ anselm
Thanks for sharing, I think many users will find some of your titles useful, but you really should start your own thread for this and not hijack elgaf's 'Universal Title Controller' thread.
hnato
#88 Posted : Friday, August 5, 2016 6:10:20 PM(UTC)
hnato
Hi anyone,
could anyone help me to create / or to create for me by you some vMIX API for import XML for football (soccer) game?
i need to import names of home/away team, names of players, lineups and players on bench, name of player with yellow/red card, names of players for substitution. and then time and score of the game.
i am not so IT skill to do it myself.
there is a special graphic on #21 from corporatejames for basketball game. do you know what is it for? is it possible to buy it somewhere? is it also for football (soccer)?
thanks
corporatejames
#89 Posted : Friday, August 5, 2016 6:35:41 PM(UTC)
corporatejames
Hi @Hnato
The graphics you see are all were created by me and all the data is pulled from my CMS SQL Database using the XML ExternalData control in UTC.
I have manually programmed the xml feed in the past in the xaml using compiled dll in visual studio but using UTC has made it 100% easier now
with out the need to compile a dll. I can just design the XAML graphic titles and animations.
ASN demo with UTC
This video shows some of the XAML titles. All the images are pulled from the database as well.
hnato
#90 Posted : Saturday, August 6, 2016 5:44:46 AM(UTC)
hnato
corporatejames wrote:
Hi @Hnato
SKTV demo with UTC
thanks for reply.
do you know who can prepare for me xml feed by using UTC?
thanks
theonlyboink
#91 Posted : Wednesday, August 10, 2016 11:25:59 AM(UTC)
theonlyboink
Hi guys,
I am currently experimenting with UTC and I must say it is an
impressive software. Great work!
I have however not got the NDI monitor to work.
I can create; Buttons, Label, List, Score, Text Field, Timer, External Data, Container and Multi State.
If I have understood things correctly the NDI-monitor is created through "External Data, right?
vMixUTC_GenericXmlDataProvider & vMixUTC_NDIMonitorDataProvider have both been installed been added to the UTC folder.
Vmix is running on the same computer and I have activated so PGM and sources are shared trough NDI.
The Sources can be found via the free version of Newtek NDI connect.
So what might I be doing wrong?
Regards
Marcus
elgarf
#92 Posted : Thursday, August 11, 2016 12:30:40 AM(UTC)
elgarf
Russian Federation
@theonlyboink, to create NDI monitor you need add ExternalData widget, and then set Path property to vMixUTC_NDIMonitorDataProvider.dll.
ExternalData widget is a way to load "plugins", such as NDI monitor, Xml data, etc.
tkachuk.alex
#93 Posted : Thursday, August 11, 2016 4:42:10 AM(UTC)
tkachuk.alex
Ukraine
Sorry, but how to add replay control buttons to UTC. Is this function released?
elgarf
#94 Posted : Thursday, August 11, 2016 4:51:42 AM(UTC)
elgarf
Russian Federation
@tkachuk.alex,
there are ReplayMarkInOut and ReplayPlayLastEventToOutput script functions, you need just add button widgets, and set their scripts to corresponding functions. If you need any other functions, you can add them into Functions.xml file using this page as reference.
tkachuk.alex on 8/11/2016(UTC)
tkachuk.alex
#95 Posted : Thursday, August 11, 2016 5:19:04 AM(UTC)
tkachuk.alex
Ukraine
@elgarf
thx for replay. I'm not good at programming but I'm trying to make it.
But I have another problem. Yesterday I start to make my own UTC preset for soccer event, save ita and today I can't open it. "Unhandled exception has occurred in your application. If you click Continue..."
tkachuk.alex attached the following image(s):
elgarf
#96 Posted : Thursday, August 11, 2016 5:37:56 AM(UTC)
elgarf
Russian Federation
@tkachuk.alex
Can you send me your *.vmc file and/or last log from "YourDocuments\vMix UTC\logs" folder?
tkachuk.alex
#97 Posted : Thursday, August 11, 2016 5:49:17 AM(UTC)
tkachuk.alex
Ukraine
I attach vmc file at previous post, just delete *.jpg at the name of a file.
I find the log. Remove today log and try 1 time to load, and the result is below:
2016-08-10 12:48:07.1656 INFO Loading widgets.
2016-08-10 12:48:10.3438 ERROR Dispatcher unhandled exception. System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.InvalidOperationException: There is an error in XML document (2, 950). ---> System.NullReferenceException: Object reference not set to an instance of an object.
at vMixAPI.StateExtensions.InputSetPosition(State state, Int32 input, Int32 milliseconds)
at vMixAPI.Input.InternalPropertyChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at vMixAPI.Input.set_Position(Int32 value)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read24_Input(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read28_State(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read30_vMixControlMultiState(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read31_vMixControl(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read32_ArrayOfVMixControl()
--- End of inner exception stack trace ---
at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
at vMixController.Classes.Utils.LoadController(String fileName, MainWindowSettings& windowSettings)
at vMixController.ViewModel.MainViewModel.<get_LoadControllerCommand>b__79_0()
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at GalaSoft.MvvmLight.Helpers.WeakAction.Execute()
at GalaSoft.MvvmLight.CommandWpf.RelayCommand.Execute(Object parameter)
at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
at System.Windows.Controls.MenuItem.InvokeClickAfterRender(Object arg)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
2016-08-10 12:48:10.3458 INFO Checking vMix server.
elgarf
#98 Posted : Thursday, August 11, 2016 6:04:41 AM(UTC)
elgarf
Russian Federation
@tkachuk.alex
Ok, that's was my fault with MultiState widget. Just download fixed version from first post.
tkachuk.alex
#99 Posted : Thursday, August 11, 2016 6:08:52 AM(UTC)
tkachuk.alex
Ukraine
@elgarf thx a lot. You've make a GREAT WORK
moth
#100 Posted : Friday, August 12, 2016 7:21:59 PM(UTC)
moth
You have been a member since:: 2/1/2016(UTC)
@elgarf - I'm having a problem with the title controller on one particular machine. The scripts section appears vacant when I select the dropdown menus. Any idea why? Works great on other machines.
Guest (12)
66 Pages«<34567>»
