AlanZ
#1 Posted : Wednesday, July 13, 2016 4:11:18 PM(UTC)
AlanZ
I have an HD license of vMix.
My question is if the software will let me use a 4k camera input and allow output of 720p video.
The use case is this... have one 4k camera and several virtual inputs, each cropped differently to 720p (for example a panel discussion with one input per panelist)
So it's unclear to me whether the HD license is not able to accept 4k as input, or if it's just a restriction on rendering 4k video.
I don't have a 4k input stream to test with, so your input is helpful.
Thanks in advance
AlanZ
#2 Posted : Wednesday, July 13, 2016 4:13:24 PM(UTC)
AlanZ
I am thinking along the lines of what a Mevo does, but doing it with vMix in control
https://getmevo.com/
https://getmevo.com/videos
#3 Posted : Wednesday, July 13, 2016 5:15:51 PM(UTC)
@ AlanZ
It is my understanding that vMix will not accept any Input sources greater than the version license, regardless of Output resolution used.
ie vMix SD will not accept HD or 4K sources and vMix HD will not accept 4K sources or higher.
ask
#4 Posted : Wednesday, July 13, 2016 6:24:31 PM(UTC)
ask
It is laid out clearly here: http://www.vmix.com/purchase/
AlanZ
#5 Posted : Wednesday, July 13, 2016 6:53:47 PM(UTC)
AlanZ
Actually, to me, it's not quite clear from that grid as to whether the restrictions are on input or on output (or both)... it just says maximum resolution, hence my question.
Kelvin
#6 Posted : Thursday, July 14, 2016 2:40:50 PM(UTC)
Kelvin
I can confirm that the SD version will not accept any inputs with a resolution greater than SD. I would assume the HD version works the same way as well. I have since upgraded to HD, but I can't confirm how the HD version works because I don't have any 4K sources.
Kelvin
r@wisla
#7 Posted : Thursday, July 14, 2016 3:05:07 PM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
If you want to use 4K input, you need 4K license. It doesn't matter if you are streaming it SD, HD or 4K.
AlanZ
#8 Posted : Thursday, July 14, 2016 3:24:44 PM(UTC)
AlanZ
Thank you, one and all for the clarification.
