The current version of vMix displays only the CPU used by vMix (at the bottom of the main window). As the total CPU used by all the processes in the PC affects the final result, I would like to have this information displayed too. For example something like this:
EX FPS: nn fps Render Time: x ms CPU (vMix): yy % CPU (all processes): zz %
Ideally it would be nice to show each individual core, but I guess that is harder to implement. (We currently use the Windows gadget "All CPU Meter" when trimming in new configurations).
 2 users thanked richardgatarski for this useful post.
Rank:: Advanced Member
Joined: 8/2/2013(UTC) Posts: 1,098   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
Joined: 3/17/2013(UTC) Posts: 235  Location: Indiana Thanks: 95 times Was thanked: 30 time(s) in 28 post(s)
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
Joined: 10/29/2013(UTC) Posts: 57 Location: Conroe TX
Thanks: 6 times Was thanked: 5 time(s) in 5 post(s)
Thanks: 1 times Was thanked: 5 time(s) in 3 post(s)
Seems that, at least on my production PC, that there is a discrepancy between the vMix CPU display and the Task Manager Display for vMix. - Tom sinc747 attached the following image(s):  vMix CPU vs Task Manager.PNG (37kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
Joined: 6/4/2014(UTC) Posts: 81  Location: USA Thanks: 40 times Was thanked: 9 time(s) in 9 post(s)
Joined: 1/13/2010(UTC) Posts: 5,313  Location: Gold Coast, Australia Was thanked: 4708 time(s) in 1613 post(s)
I'll look at adding a Total CPU usage level to the vMix status bar soon, but keep in mind it won't match exactly what is in Task Manager or indeed other CPU monitoring applications. The reason is...complicated.. as strangely enough there isn't one way to measure CPU usage! For reference the vMix method will match the Windows Performance Monitor: https://technet.microsoft.com/en-us/library/cc749249(v=ws.11).aspxSo that was my hesitation in adding this previously as I feared people would report a discrepancy and suggest that it is inaccurate somehow.. Regards, Martin vMix
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
Although this will be a valuable feature for quick reference, it probably won't keep me from continuing my practice of always opening a Task Manager window to monitor these things during a broadcast or session (usually on my second monitor).
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
+1
In the meantime a quick way to monitor the total cpu use is: open taskmanager, go to options and enable minimize at use and hide when minimized. After minimizing only a small cpu meter icon will appear in the tray and you can quickly see the processes by double clicking it.
Put C:\Windows\System32\taskmgr.exe in start menu, startup and the icon will show up every time in the tray.
 3 users thanked admin for this useful post.
Awesome! Works great. Much appreciated.
- Tom
It works good enough to leave the task manager closed from now on. Thank you very much.
