PFBM
#1 Posted : Tuesday, June 21, 2016 7:28:42 AM(UTC)
PFBM
HI !
for low cost machine.... what is best ?
( all socket 2011 )
I7 quadcore 3.6 ghz ? or Intel® Xeon® Processor E5-2670 8 Octocore HT cpu ? or .... dual xeon of those ?
http://ark.intel.com/pro...0-GHz-8_00-GTs-Intel-QPI
with a 960 or 970 GTX 4 gigs of ram doing up to 8 HD Cameras
Best Regards ,
PFBM
desmar
#2 Posted : Tuesday, June 21, 2016 9:35:16 AM(UTC)
desmar
Canada
PFBM wrote:
HI !
( all socket 2011 )
Best Regards ,
PFBM
If you are going to use NDI then the Xeon you quoted does not support SSE4.1/4.2, AVX 2.0 but only AVX and no SSE. NDI minimum spec requires SSE 3 and AVX.
PFBM
#3 Posted : Tuesday, June 21, 2016 11:27:36 AM(UTC)
PFBM
desmar wrote:
PFBM wrote:
HI !
( all socket 2011 )
Best Regards ,
PFBM
PFBM attached the following image(s):
Kelvin
#4 Posted : Tuesday, June 21, 2016 12:04:10 PM(UTC)
Kelvin
Which I7 processor are you considering?
PFBM
#5 Posted : Tuesday, June 21, 2016 1:36:12 PM(UTC)
PFBM
Core i7-4960X i already have it . it works but.... considering testing this powerfull cheap xeon :)
as you can see on the specs... this xeon has all the SSE´s ... :)
Kelvin
#6 Posted : Tuesday, June 21, 2016 3:57:58 PM(UTC)
Kelvin
The 4960 is a nice CPU. I believe it is 6 core, not 4. I have a system built around the 6-core 3930 and a GTX 970 that handles 4 HD signals flawlessly. Can't comment on more than that.
Mathijs
#7 Posted : Friday, June 24, 2016 12:17:48 PM(UTC)
Mathijs
I'm running a xeon E5-1660 6 core @4ghz with a GTX970 with a BMD quad 2 and that works flawlessly with 8 HD inputs. I think it can even do more because without streaming or recording, the cpu usage is very low and render times are below 10ms.
When you want to multicorder while streaming and recording plus use NDI, more cores is always better, but you do not need newest hardware.
I think a 40 lane 2011 board with 40 lane CPU with a clock speed of 3 ghz or higher together with a Nvidia GTX960 or better, is a good foundation for a vmix system.
Please bear in mind that 2011-v1/2 cpu's are quite cheap, but the mainboards are not. Also the mainboards are not easy available because they are very much wanted.
If you build new, I would go with 2011-v3.
thanks 1 user thanked Mathijs for this useful post.
PFBM on 6/24/2016(UTC)
PFBM
#8 Posted : Friday, June 24, 2016 12:27:59 PM(UTC)
PFBM
check this config :
HP Z620 Workstation with
CPU: 2x Intel Xeon E5-2670
Graphic-card: GTX960
Memory: 64GB
HDD: 128GB SSD
Operating System: Windows 7 Pro 64 bit preinstalled
condition: used
net price: 1195 € + 15,-€ shipping costs
Cheers,
PFBM
Ittaidv
#9 Posted : Monday, July 18, 2016 2:41:42 PM(UTC)
Ittaidv
I'm all fan of xeons. Can't beat the price of the xeon e5 2620 for example. It's in one of my rigs and never touches 50% on 7-8 HD inputs, while recording and streaming at the same time.
I now built 2 systems with a 10 core Xeon E5-2630 v4 and a nvidia 1080 graphic card, with 8 HD inputs and 1 4k input it doesn't even touch 15% cpu load.
My opinion is that you pay a lot of extra's for clockspeed in the i7 range, while actually you need more cores.
thanks 3 users thanked Ittaidv for this useful post.
PFBM on 7/19/2016(UTC), BloodyIron on 5/2/2017(UTC), madness on 5/2/2017(UTC)
BloodyIron
#10 Posted : Tuesday, May 2, 2017 5:56:36 PM(UTC)
BloodyIron
What did you go with in the end, and how did it run for you?
PFBM wrote:
check this config :
Memory: 64GB
HDD: 128GB SSD
condition: used
Cheers,
PFBM
PFBM
#11 Posted : Wednesday, May 3, 2017 3:35:42 PM(UTC)
PFBM
HI !
vMix on a Z600 dual exacore xeon X5670
GTX 960 4 gigs of ram
magewell quad hdmi 4 cameras on.
triple stream : Wowza - facebook - Periscope
recording Vc3 mxf final master
stereotool vst audio processing on virtual cable before vmix audio input
logo overlay...
total machine cpu used : 24%
audio processing eats 10% of it
Cheers,
PFBM
thanks 2 users thanked PFBM for this useful post.
BloodyIron on 5/3/2017(UTC), entropywu on 10/11/2017(UTC)
BloodyIron
#12 Posted : Wednesday, May 3, 2017 4:40:38 PM(UTC)
BloodyIron
Sick info! Are you doing any multicorder stuff too? Do you ever see it go higher than 24%?
PFBM wrote:
HI !
logo overlay...
Cheers,
PFBM
PFBM
#13 Posted : Wednesday, May 3, 2017 4:54:28 PM(UTC)
PFBM
Will test it and tell later :)
Cheers,
PFBM
thanks 1 user thanked PFBM for this useful post.
Roberto Santana
#14 Posted : Wednesday, December 16, 2020 9:15:15 PM(UTC)
Roberto Santana
Brazil
Alguém ajuda ?
Estou com o KIT X99 Palca Mãe Atermiter(Chinesa), Processador Xeon 2620 v3,
Placa de video 1050 ti 4gb
Quando coloco a camera e clico no PTZ pra dar zoom dentro do programa, fica piscando ou
quando vou fazer choma key pelo programa, acontece o mesmo, piscando, alguém, sabe me informar
se esse kit tem algum problema com o VMIX.
Obrigado pela atenção!
Guest (4)
