gregonemedia
#1 Posted : Monday, June 20, 2016 4:23:11 PM(UTC)
gregonemedia
Hi I'm new to vmix, the website says download the trial version for 60 days but i can't seem to use it in full hd to test my hd cameras.
i keep getting only the free section which is SD
What am i doing wrong?
Mathijs
#2 Posted : Monday, June 20, 2016 4:45:44 PM(UTC)
Mathijs
I guess you selected the wrong option. You need to select the free 60 day trial instead of the free SD version.
You can reset your registration in the settings. Go to "About" and click "Change Registration Key".
After you changed it to the 60-day trial, setup your desired output size at "Display" and change the "Output Aspect Ratio" to "Widescreen". You can now use vMix for 60 days in HD.
Success
gregonemedia
#3 Posted : Monday, June 20, 2016 5:46:21 PM(UTC)
gregonemedia
Success
Thanks i try'd but keep saying key as expired
sinc747
#4 Posted : Tuesday, June 21, 2016 1:19:27 AM(UTC)
sinc747
Are you in the US? If you're stumped, shoot me a PM and let's see if I can't help.
- Tom
