60 day Trial not working for me help
Hi I'm new to vmix, the website says download the trial version for 60 days but i can't seem to use it in full hd to test my hd cameras. i keep getting only the free section which is SD
What am i doing wrong?
I guess you selected the wrong option. You need to select the free 60 day trial instead of the free SD version. You can reset your registration in the settings. Go to "About" and click "Change Registration Key".
After you changed it to the 60-day trial, setup your desired output size at "Display" and change the "Output Aspect Ratio" to "Widescreen". You can now use vMix for 60 days in HD.
Success
Mathijs wrote:I guess you selected the wrong option. You need to select the free 60 day trial instead of the free SD version. You can reset your registration in the settings. Go to "About" and click "Change Registration Key".
Success Thanks i try'd but keep saying key as expired
Joined: 8/2/2013(UTC) Posts: 1,109   Location: Fairhope, Alabama USA Thanks: 603 times Was thanked: 204 time(s) in 170 post(s)
Are you in the US? If you're stumped, shoot me a PM and let's see if I can't help.
- Tom
