Thanks: 5 times Was thanked: 18 time(s) in 18 post(s)
Hello, I never had an issue on streaming until now. In one of my Church client, they stream on Dailyimotion since 2014. The actual versionof Vmix installed is the 16.xx Primary they use FMLE through Vmix streaming setup and all are working good until now. Today, it's impossible to make any stream I try then with FFMPEG and we succeed to stream not more than 1 minute and the Streaming Button goes green to yellow. In attachment the diag image of dailymotion to see the number when we begun and the number when the issue appear, and attached also the log of ffmpeg if someone could help me to interpret it. I don't know if this issue is related to vmix or not The Up internet speed is 1Mo so we set the upload on 500 Kb (640*360 for the video size) and normaly is working fine till now Thanks C. File Attachment(s):  streaming 20160616-071255.txt (99kb) downloaded 3 time(s).Charssay attached the following image(s):  16-06-2016 07-14-24.jpg (72kb) downloaded 2 time(s). 16-06-2016 07-15-52.jpg (78kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
try set the strict cbr on, the ffmpeg is a little permissive and if need use alot of bandwith and later uses lower to keep the media in the 500kbps but if your upload is not very good this can more that your upload.
