Rinsky
#1 Posted : Thursday, June 9, 2016 9:01:43 PM(UTC)
Rinsky
I just tested a new setup including a few NDI inputs and when I started the livestream I got following error message in the streaming console after some time:
"[dshow @ 02578740] real-time buffer [vMix Video] [video input] too full or near too full (62% of size: 256000000 [rtbufsize parameter])! frame dropped!"
The stream was not really whatchable, lot's of frame drops and choppy audio, but the GPU and CPU load weren't that high.
Problem occured when streaming with hardware encoder and without it.
The problems ended, when I turned off all NDI inputs.
Mathijs
#2 Posted : Thursday, June 9, 2016 9:31:35 PM(UTC)
Mathijs
Are you sure your network is doing Gbit? Maybe there is a bad cable from your system to the switch forcing it to 100mbit?
The streaming console throws exactly that error when there is congestion and it cannot upload it's encoded stream.
So first check your network for problems.
Rinsky
#3 Posted : Thursday, June 16, 2016 8:05:25 PM(UTC)
Rinsky
I deactivated one of my NDI Inputs (I was using 2) and now everything works just fine, but it still wonders me, because I use the Huawei E5186 Router, which has 4x Gigabit LAN (and yes I'm using it over cable)
Is there a way to see how much bandwidth NDI uses?
richardgatarski
#4 Posted : Friday, June 17, 2016 5:40:51 PM(UTC)
richardgatarski
Rinsky, you can use Windows' performance monitor (eg via ctrl-alt-del)
r@wisla
#5 Posted : Saturday, June 18, 2016 6:24:51 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
Your PC-s LAN card is 1gbps too, right?
Rinsky wrote:
...because I use the Huawei E5186 Router...
I had issues with NDI and very similar Huawei Router too. So I used a Netgear 1gpbs switch, connected 3 PC-s to it + this router and there was no problem since then.
Streamevent
#6 Posted : Saturday, June 18, 2016 6:51:09 AM(UTC)
Streamevent
Had the same problem with a 4-port Gigabitrouter and 3 rtsp streams.
My solution was the same, connecting all cameras, Vmix and the internetrouter to a switch did solved the issue.
I think there is not enough thruput at the build-in router switches.
Rinsky
#7 Posted : Saturday, June 18, 2016 10:58:05 AM(UTC)
Rinsky
Thx! I'll buy a gigabit switch
Rinsky
#8 Posted : Thursday, June 23, 2016 7:32:12 PM(UTC)
Rinsky
The switch solved the problem. THX
thanks 1 user thanked Rinsky for this useful post.
mjgraves on 6/24/2016(UTC)
Guest (6)
